SOURCE: Double Vision....
the problem on my sony projection tv is double vision,what equipment i need and how much it is. also is it easy to fix on my own?
SOURCE: I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
SOURCE: blurry screen double vision picture
The convergence circuit has failed. It is not a easy fix due to the tear down needed to get to the circuit area. I would call Mitsubishi at 18003322119 to get a Authorized Service Facility to check it out and give you a estimate of repair cost.
SOURCE: how to I fix the picture that is red and greenish
Replace Both of your convergence ICs STK392-110 use 150s they are big black ICs will have part number on hem Call Mats 1-800-628-1118
SOURCE: double vision on t.v screen
Hi frank
To answer your question;
The problem with your tv is caused by the convergence circuit.
If you can`t adjust it anymore it means that some parts have gone bad in that circuit.
It is repairable and you or a friend can do it.
I`m going to leave you a couple of web addresses where you will find the parts and instructions on how to do it and also the tools you`ll need.
For the parts:http://www.tvrepairkits.com/xcart/home.php?cat=1662
For the tools(recommended) if you don`t have them already:
http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=e3fab1b8cee368315ca4bf73be5a2a83&keywords=sd1284&x=7&y=5
Hope this helps
Good luck
