1998 Toyota Avalon Logo
Posted on Dec 21, 2009
How to disable 98 Toyota Avalon Alarm
I have a 1998 Toyota Avalon. If I go to start the car the alarm will go off and the car will not start. Even if the alarm is disabled it does the same thing. Is there a way to disable the alarm on the car maybe my a fuse or a switch or something so that I don't have to worry about this?
  • daichi2000 Jun 09, 2016
    pay best buy $50, to remove factory alarm that disable vehichle; I had viper remote installed, has more feature and better then factory, remember it's a 1998
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6503
Points
17
Disable alarm on 96 avalon
  • Anonymous Feb 13, 2012
    Look under your dash. There should be a toggle switch to cut the alarm in and off somewhere by the left kick panel.
1helpful
Need to disconnect security system on 98 Toyota camry
If I remember correctly if you unlock the drivers door with the key from outside twice it disables the arm just like the key fob would have but only if it is a factory alarm system.
Reset factory alarm on a toyota avalon xls 1996
If the alarm system has a battery remove it otherwise removing the car battery for a while may reset it. In emergency contact your local toyota dealers mechanics department and they may be able to help you at no cost.
If you put a general enquiry on google you might get lucky, do not be too specific. i.e. toyota 1994 alarm reset procedure
3helpful
My alarm is activating itself. How can I permenantly disable the alarm? I've had to do it before but I can not remember which fuse we removed.
When you close the door, the alarm will arm itself even if you do not set it. When you open the unlocked door, the alarm will sound.
2helpful
Resetting the alarm system. when putting in a new battery, the alarm keeping going off.
no problem, connect battery and then use key to lock and then unlock the driver door, this will shut down alarm. hope this helps.
2answers
1998 toyota Avalon, the car alarm is going off when opening the drivers door manually with the key (remote is broke) and then the car will not start.
Same here... I have a 1998 Toyota Avalon XL. My car battery died. Replaced my car battery, but found out that when you unplug and plug the car battery with this car it engages in security mode (I have factory car alarm). This disables the engine and wont let you turn the ignition aka start the car engine until the remote (keyless entry) "UNLOCK" is applied. My remote is also lost so I cannot disable the alarm.
The only thing I can think of to do is unplug the battery again to disable everything (car alarms are annoying...) and call the dealer to pick the car up and perform the diagnosis. Most likely they will offer you another keyless (ugh... expensive) and/or you could ask to disable the factory car alarm.
I know thats not much help but it seems to be the only option from what I researched currently....
The alarm goes off every time I try to start the car.
when you disarm the alarm make sure you hear a beep beep sound twice before you try to start the car.
I have a 1992 toyota camry. My alarm has been
Without the schematics for the alarm. I would look for the alarms controller /relay and remove it. Use fuse diagram in the owners manual to see whats stock and whats not if its an aftermarket alarm.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
