Un-install the drivers that you have installed. Use a system utility tool like PCFresher to optimize pc and fix windows errors. After scanning pc with this tool fix all errors found. Restart the PC and re-install the drivers.Hope problem is fixed.
The best thing to do first, is to first uninstall you printer and than re-install your printer and download the newest printerdriver for Windows Vista.
The problem correspondent to this error code is: "Error relating to PCL emulation problems occurs." The solution is: · Press the "Return" buttonto clear the message, cancel the current print job, and conduct the next print job, if any.Press Cancel to cancel the print job.
Simply press the PAUSE button then press CANCEL. If you have sent a batch of 500 labels, though, you will have to press CANCEL 500 times. I usually just turn the printer off, cancel the job in the printer driver status box, then wait for all of the error messages to pop up.
controlpanel, printers, open yours, delete the job.
it may be that you are required to have administrative priviledges to do this. If this is your computer, go to the control panel as an administrator user and change your user settings.
Delete Queued Print Job
If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
On the Windows taskbar, double-click the printer icon located to the left of the time.
At the Printer window, select the print job, under 'Document Name' column, to highlight it.
From the 'Document' menu, select 'Cancel'.
Repeat steps two and three to cancel another print job.
Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
Close the Printer window.
Shut down the computer.
Disconnect the printer cable (USB or parallel cable).
Restart the computer.
If a message window appears asking to cancel printing, select 'Yes'.
Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
Applications that are reading file allocation table (FAT) based storage devices at
the time of a resume may receive the following error message from the file system:
ERROR_ACCESS_DENIED (0x00000005)
This occurs although the file has appropriate sharing and access
permission.
Examples of storage media that frequently use the FAT file system on
Pocket PC 2002 are the PCMCIA PC Card ATA, the Compact Flash (CF) Storage Card, and
the Secure Digital (SD) Memory Card.
This behavior is observed when using Pocket
PC 2002 Adaptation Kit Update 4 (AKU4) and later.
RESOLUTION:
Applications can handle this situation by detecting the
specific error code while reading a storage card file, and then retrying for a short
period until the device is ready. The following is an example C code fragment
that demonstrates this concept:
while ( !WriteFile( hFile, achBuffer, dwBytesRequested, &dwBytesReturned, 0 ) && ( ERROR_ACCESS_DENIED == GetLastError() ) ) { // Access Denied: Maybe the file system is not ready yet. tries++; if ( tries > 4 ) break; Sleep(500); } // It has been a few seconds. The file cannot be accessed.
You can use the same approach for other programming languages.
For applications that access the storage card through middleware libraries that
do not provide direct access to the file system, you may have to implement
transactional or block verification methods to get reliable data transfer
across a suspend resume.
