Google Chrome Logo
Anonymous Posted on Dec 20, 2009
I am unable to customize my links. I put "Links" in the taskbar, I have rearranged them the way I would like for them to appear on the bar and Nada, nothing. They were "imported" alphabetically and that's the way they are now notwithstanding they are listed the way I want them on the links page.
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Dec 21, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
1431
Points
10
That is odd. You should be able to drag them in the order you want them to appear. Have you tried to do it another way by clicking on the wrench icon, choosing Bookmark Manager and changing the order that way?
Testimonial: "The way I finally got it to work was to go to the Links Bar and click on ">>". I dragged and dropped from that screen although it was unwieldy. Thnx"
E bar displays and won't open help
If you are seeing an "E" bar on your computer screen and are unable to open it, it is possible that the "E" bar is a part of your operating system or a program that is running on your computer. The "E" bar, also known as the taskbar, is typically located at the bottom of the screen and contains icons for the programs and features that are currently open or available on your computer.
To open the "E" bar, you can try the following steps:
  1. Move your mouse cursor to the bottom of the screen, where the "E" bar is located.
  2. Click on the "E" bar to select it, and it should open and expand to show the icons for the programs and features that are currently open or available.
  3. You can then click on any of the icons to open the corresponding program or feature.
If you are still unable to open the "E" bar, it is possible that it is hidden or minimized. To unhide or unminimize the "E" bar, you can try the following steps:
  1. Press the "Windows" key on your keyboard to bring up the Start menu.
  2. Type "taskbar" in the search box, and then select "Taskbar settings" from the list of results.
  3. In the Taskbar settings window, you can adjust the settings for the "E" bar, such as its position on the screen, the size of the icons, and whether it is always visible or only appears when you hover your mouse over it.
  4. Make any necessary changes to the settings, and then click "Apply" to save your changes and make the "E" bar visible again.
If you are still unable to open the "E" bar after trying these steps, it is possible that there is a problem with your operating system or a program that is running on your computer. In this case, you may need to restart your computer or contact technical support for further assistance.
tip
How to hide unused links from your Start Menu
It's much better when your desktop menu is customized to your comfort also when you can remove things you don't use and add things you do use.
Follow these very simple steps below:
1. On your desktop "Right-click" on your taskbar (the long bar located at the bottom your screen.
2. Now click on "Properties".
3. Now another dialog will come up, now click on the link "Start Menu".
4. Now click on "Customize".
5. Now another dialog will come up, click on the link called "Advanced".
6. Now let the customization begin.
How to know if battery is full charged?
Look on your task bar for the battery icon. If you don't see one , right click the taskbar, click on properties, in notification area click on custom button, the look for b attery icon and have it show on your task bar if not already selected. when your icon appears on the task bar, just hover on the icon, it will tell you the state of your battery
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Have lost internet explorer icon at bottom left of screen
Not enough information,,do u mean u lost IE icon in Windows 7 OS task bar? or lost icon from startup menu?
You can pin the icon back to taskbar in win 7 by:
go thru the below link
http://www.sevenforums.com/tutorials/397-taskbar-pin-unpin-program-links.html
THE TASK BAR APPEARS AT THE TOP OF THE WINDOW
First, make sure the taskbar is not locked. Right click the taskbar and make sure the is no check mark beside 'Lock the taskbar".
Now, point your cursor just beside the START button (outside the START orb and on the task bar), click and hold and now you can move it to the bottom of the window.
I hear a poping noise when i turn a corner from
Definitely the sway bar links. New links are extremely stiff at the balljoint. Old ones appear OK until you compare them to new ones.
1helpful
I run Windows XP Professional. Today there showed up a second layer of taskbar. It has ''Desktop'' in light blue, ''My Documents'' ''My computer'' and ''My Network Places'' shown in white with icons. ...
You have only increased your taskbar size, don't worry...
Right-click on an empty part of the taskbar, and ensure the "lock the taskbar" is unchecked. Next, position your mouse right on the top edge of the taskbar, your mouse should change to two black opposing pointing arrows. Hold left-click, and drag the taskbar down.
This will reduce the taskbar back to the way you're used to.
Hope this helps, and please rate this answer.
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
