Televison & Video Logo
Posted on Dec 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just got direcrt tv and there isnt any codes for ilive sound bars wnat to do
Anonymous
Level 2:
New Friend:
  • Expert 29 Answers
  • Posted on Dec 21, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
29
Questions
0
Helped
13232
Points
123
Try this
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Good Luck:)
ILive Sound Bar. I need the code for Philips Universal Remote to program my iLive Sound Bar please?
Best advice here
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
So many codes, good luck with that :>)
3-Digit Codes
  • 856
  • 734
  • 837
4-Digit Codes
  • 2113
  • 3175
  • 0816
5-Digit Codes
  • 33279
  • 72303
  • 32113
  • 23175
  • 33175
  • 42113
  • 31957
  • 43175
iLive remotes
https://www.google.com/search?q=iLive+Sound+Bar+replacement+remote
I have a ilive sound bar but when I took it up to my insignia tv with aux cable it just buzzes. What can I do?
I went online and looked at the ilive 2.1 manual to see the Connections on the back and I see RCA input and output. I would 1st make sure that the Audio cable is working okay on something else then hook up the TV Audio out to the ilive Audio input. Make sure in your TV settings that the volume is going through okay, if so and there's still a problem, then it would be in the ilive sound bar. Hope that helps
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
1helpful
Can my Samsung TV remote drive my ilive sound bar?
Unless the sound bar is a Samsung or if the remote is a programmable remote. It cannot operate the iLive sound bar.
How to connect ilive ITP180b sound bar to a 55"Emerson?
http://www.manualslib.com/manual/257417/Ilive-Itp280b.html
4helpful
2answers
Three digit code for ilive sound bar
Hi Scott, my name is Cheri Torres and I work with the DISH Network Internet Response Team. I came across your post and wanted to help! I will list here for you the best code for your iLive sound bar and also the instructions for addressing the remote to your sound bar. I hope you find this information useful and if you have further questions please let me know!
The best code 2835
The instructions for addressing the remote.
1. Press and hold down the AUX button until all the other mode buttons light up.
2. Enter the code 2835.
3. Press the pound(#) button once.
4. Test the functionality of your iLive sound bar.
2answers
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
