this problem come from your har drive
your hard drive not recognized by motherboard
to solve, open your computer, disconnect hard drive cable then connect again
then turn on your computer
this problem usually found on computer with sata hard drive
Hello, you can download the drivers from the canon support page. The link below is for widows XP, however you may selct a different operatig system from the drop down box.
I hope this helps ans solves your problem, Regards
try to pres the sleep button after the computer sleep (indicates from the indicator ligh) than press slep buton again if that is make your screen coming on it because the batery or the power, but if theres nothing than try to reinstll the Operatig System if your screen dosn't appear from the start maybe caused by 4 problem 1. maybe your flexible cable that conected the mainboard to lcd (screen) is untigh or broken 2. your screen is broken 3. your lcd inverter need to be replaced 4. your vga is crash to identifying try to conect to the external display like monitor if on the monitor appear it maybe caused the problem no 1-3 try to open your up panel (up side of the keyboard) try to tigh the cable (usually have black power) make it tigh and tape it using duck tape
do a thorough scan you system for viruses if you do not do so regularly
do a surface scan of you hard drive
3 possible solutions (assuming widows os as you do not say)
1 insert you os installation disc - go to control panel \ system \ hardware \ device manager \ sound \ (audio hardwares) - select all audio drivers - right click, update
2 go to http://welcome.hp.com/country/us/en/support.html download audio drivers specific to you model, install per their instructions
3 if you have install one of the many quirky av apps you have to go to their website to download & install their proprietary drivers
No absolutely not. This is happen when you delete your some system files on C: drive. It doesn't crash at once, But when you reboot. So don't ever delete your sys files. Now you can do is repair windows using the XP sp3 CD. Or replacing sys files using another OS.
Think this is helpful !
Have you tried booting the system with the restore disk, well it should reformat the system before it installs a fresh copy of windows 98 so you should back-up data before proceeding and check the boot sequence in your bios, set the first boot device to CD/DVD.
Many problems relating to camera connection issues relate to hardware other than the Nikon camera. There are numerous compatibility issues between USB Controllers, motherboards, main CPU chips and different versions of the Windows operation systems. Below are some helpful links.
The Microsoft web site has information regarding USB Troubleshooting for Windows 98, Windows 98 SE and Windows ME. http://support.microsoft.com/support/kb/articles/q263/2/18.ASP
The Microsoft web site also has information regarding general compatibility between Windows and different USB controllers. Select "USB controllers" on the link and then find your USB controller on the list, if your controller is not listed as compatible or "logo" with your current operating system you may need to upgrade your OS, or work with alternate hardware.
http://www.microsoft.com/hwdq/hcl/default.asp
The Compaq web site has information regarding issues with their Deskpro 2000/4000 USB and Windows 2000.
http://www.compaq.com/support/techpubs/customer_advisories/DG000117_CW01_0.html
The Microsoft web site has information regarding issues between AMD Processors and Windows SE.
http://support.microsoft.com/support/kb/articles/Q240/0/75.ASP
One method for restoring USB functionality is to remove the currently installed USB Controller (from the Device Manager). Be sure to have the Windows installed disks available as you may be prompted for them.
To accomplish this:
Open the Device Manager (right click on "My Computer" and choose "Properties"
Windows 98 and ME have a "Device Manager" Tab Windows 2000 and XP will have a button in the "Hardware" tab
Click the "+ " sign next to item named "Universal Serial Bus controller" and highlight the "Unviversal Host controller" found beneth it. Once the item has been highlighted press "Delete" on the keyboard
Refresh the Device Manager
With Windows 2000 and XP choose "Scan for Hardware changes" from the "Action" menu. With Windows 98 or ME click "Refresh"
If you were prompted for the install CD or to restart the computer there were definite driver changes made and any USB issues may be resolved.
