Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
Posted on Dec 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I don't know what model Motorola bluetooth headset I have but I don't know how to get it into discoverable mode to sync it to my phone.
J. Van
Level 3:
President:
  • Master 1,738 Answers
  • Posted on Jan 29, 2010
J. Van
Master
Level 3:
President:
Answers
1738
Questions
Helped
624201
Points
5775
Most Motorola headsets automatically go into pairing mode when you turn them on. If you have a light on your headset, it will be pink when you turn it on (and will begin flashing) and then change to blue. When the light is pink it is ready to pair. If you don;t have a light on your headset, it will stay in pairing mode for 10-15 seconds.
Turn your headset OFF then, (with your phone turned ON) in your phone's menu (usually) you'll go to Settings > Connectivity > Bluetooth (and select ON) Then select, Search for Bluetooth Devices and at this point you want to turn your headset ON.
It may take a couple of tries to get your phone to locate your headset but when it does it will identify the headset by the headsets model number when it locates it.
The pairing code should be four zeros. 0000.
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
1helpful
Iphone
while the phone is tring to locate the ear peice, press and hold the button on the ear piece till it blinks the flip it open and see if the phone finds it.
How do i sync my ht820 to my samsung flip phone, phone says place bluetooth device in discovery mode and I dont know how to do that\
To connect your headset to your phone, press and hold the "M" button on the left side of the headset for 6 seconds until the indicator light turns on and remains steadily lit.
Next, put your phone into pairing mode by going into your Bluetooth settings and searching for a device. Once your phone has found your headset, you can sync them together.
1helpful
2answers
4helpful
I have a motorola hs850 and it keeps flashing blue and it cannot go into discoverable mode need some help thanks
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
8helpful
2answers
Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
Maual for Motorola H350 bluetooth headset
To pair your bluetooth with your new phone...
Step one: make sure bluetooth is fully charged. While off, press down and hold the mulitifunction key on the bluetooth until light remains on.
Step two: put your phone in discoverable mode and click on add new device to search.
The phone will then find the bluetooth.
1helpful
I'm trying to set up my new blackberry 8830 to work with motorola and jawbone bluetooth units. i've enabled bluetooth on blackberry. i've set discoverable to yes, and the led connection indicator to on. it...
you also have to have the headset on pairing mode also during the time of the attempted sync, see your documentation on your headsets on how to set it for pairing mode.
1helpful
3answers
Discoverable Mode
Here is the on-line manual: http://www.motorola.com/mdirect/demos/how2_h3/main.html -First off make sure the headset charges for at least two hours. Also make sure theindicator light turns on indicating charging is occurring. -After the charge is complete you will need to refer to your phones manual to pair the headset to the phone. The discover mode is a mode the phone goes into not the headset. I don't have an LG8600 nor can I find a manual on-line so I can't help you with that part. If you still need assistance let us know and please don't forget to rate the posting.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
