Many laptops have plastic coverings on their hinges. You can can pop these off with a screw driver and sometimes you can reach the screws to tighten the hinges from here. You may be able to tell if the hinge is broken from here as well. Many times, though, the screws holding the hinges in place are located on the bottom and you will have to remove the portion of the case that is covering them. This usually means the entire lower portion of the laptop case to access these screws.
