Computers & Internet Logo
Posted on Dec 20, 2009
Macbook turns on but screen is blank .the arrow pointer came on for awhile but went blank and stayed blank
Anonymous
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 41 Answers
  • Posted on Dec 21, 2009
Anonymous
Contributor
Level 1:
Mentor:
Teacher:
Answers
41
Questions
0
Helped
15616
Points
62
Try holding down ALT while booting up and select Macintosh HD. If that doesn't work try inserting your mac osx install CD or DVD restart hold down ALT. Select the CD using the arrow keys after the CD has loaded go up to the drop down menus and go to disk utility, then click on your main boot disk (macintosh HD) and under the First AID tab (if your using osx) click verify permissions and restore permissions, then click verify disk and repair disk. Try to boot up. If this doesn't work restart leaving work mac osx CD in hold down D then follow the disk checker steps. This will tell you if there are any errors on your disk (hard drive). If there are you need to get it fixed or replaced. If none of this works you will need to buy a 8.1gb pen drive mac osx 10.6 update ($30 USD) then follow the instructions from http://www.maciverse.com/installing-snow-leopard-onto-an-external-hard-drive.html to create a temporary start up disk. Then go to your old Hard Drive Macintosh HD (should be on the desktop) and copy/backup important files and then turn off and get a new hard drive try Ebay and ask if it will fit your macbook by using your model number found under your battery. Find instructions for install or take the hard drive to a pc shop and ask for them to switch them over. If they don't copy your old files you will need to do a fresh install with your mac osx cd/dvd.
Note: You can use the pendrive as a temporary for as long as you want, to select it hold down ALT at startup and select the disk thats not macintosh hd or a cd/dvd. If you can't find an 8.1gb pen drive get a 16gb pendrive. sorry about the URL the link button wasn't working for some reason
I have a macbook that is a year and 1/2 old. i went to turn it on today and the screen stayed black and it makes loud beeps. why is this happening?
Does it should be the battery or adapter for MacBook have some matter?Oh,it shouldn't be, it must beause the Fan of CPU or Other Fans of your MacBook Motherboards will wear out! You'd better clear and maintain it.
Blank screen, flashing keyboard, confusion
My Motorola Razor cellphone all of a sudden went blank, i took out the battery and put it back in and turned it on, but the keyboard just flashes and the screen stays blank, what do i do?
Screen will remain blank after mac is turned on sporadically.
the only place i know they fix this is london (shop name micromend ) had the same it is a common fault graphics chip fault
1helpful
Display is gone, only pointer arrow shows
Try tapping the F8 key just after you power your machine up to see if you can boot to safe mode.
2helpful
Blank screen when computer is turned on
When you get the Dell splash screen press the F2 key to get into setup. Use the arrow keys to go down to Drive Configuration and press enter. Go down to Primary Master Drive and press enter. Is the Hard Drive listed there? If not, that is your problem. Press Escape then use arrows to go down to Memory Information and press Enter. Is all of your Memory listed? If not, that could be the problem. Press "esc" to get out of setup. If the Computer does not freeze while in setup I would suspect the Hard Drive is bad. Is the Pointer responding to Mouse movement or does it lock up? In your situation I would first try to Boot from the Windows CD. Write back and I can explain how to do this. If that does not work I would begin to test Hardware. Do you hear any Beeps when the unit is turned on? If you can, E-mail back with more Info.
Unable to start....
your hard drive has prolly crashed, same thing happened to my buddies macbook. when he turned it on, it went to a blank screen.  Im sorry  but hopefully you still have a warranty on it bc it was 300 $ for a new hard drive that my buddy got.  take it in to apple and have them look at it.
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
[email protected].
Thanks
Ekow
2answers
Touchpad not working
Using your keyboard, press the windows hot key, then use the arrow keys to go up and to the right to control panel, then arrow over to the system icon, then arrow through the tabs to the hardware tab, then press TAB to select the "device manager" button and click enter....in the device manager, press tab again in order to highlight the first selection and arrow down to "mouse and other pointing devices" then press the right arrow key to expand that selection and see if it is recognizing your mouse pad, if it does, highlight it and press enter, arrow over to the "driver" tab and try updating the driver, if that doesn't work, try a troubleshoot from the first properties tab.....and if none of this works......the touchpad is most likely dead. Try contacting the manufacturer and see if they can replace the touch pad.....
4answers
Macbook start-up
http://www.retrodata.co.uk/notice_apple_seagate_drives.php
Grand Canyon Tech
Grand Canyon Tech
