I have panasonic kx-th111, its caller id does not work, i have shown it to urban telephone network, they said its program should be reprogrammed and they are not able to do it, the official service of panasonic also said the same and added that i have bought not from their shop, and also refused to helpm, how can i solve the problem...
SOURCE: manual for panasonic kx-tg5240
Here's the manual (Adobe PDF) from Panasoni's site:
http://service.us.panasonic.com/OPERMANPDF/KXTG5240.PDF
SOURCE: How do ichange the time on Panasonic KX-T7431??
How do I change the display names for each extention name on my KX-T7431 panasonic corded phone?
SOURCE: Panasonic KX-TG2357 talking caller ID
To turn Talking Caller ID on or off
You can turn Talking Caller ID on or off for the handset and base unit separately. If
this feature is off, the unit will not announce caller names. The factory preset is ON.
Handset Talking Caller ID feature
1 Press [MENU].
2 Scroll to “Talk Caller ID” by pressing [d]
or [B], then press Select.
3 Select “Off” or “On” by pressing [d] or [B].
4 Press Save, then press [OFF].
Also Refer To Page 31 Of Your Owners Manual.
If You Do Not Have The Owners Manual It Can Be Downloaded Here.
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Using Fixya.com
SOURCE: Caller id setting
An 824 in the U.S. is delivered with a CID card installed. If you have one, it's in the lower left of the cabinet, but it requires programming. At the very least, if you're uncomfortable with opening the cabinet, you can go into programming and make sure program 900 (and 913) is set to ON for your first 3 lines. This is CID.
There are other programs that deal with how it logs, prints, and behaves, but this is the main CID function.
Carl
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
