What is this? How do I fix it?
5C10 FIX IT
Same here, MP530, so turned it off at the power button on the front. Turned back on... same error. But then, pulled out the power cord from the back, then reinserted it. Error has disappeared, maybe for good, maybe not. At least I can now print!
Linda Sanders, www.ozfeathers.com.au
With an error 5c10 what can be done?
Go to the Control Panel. Double click on Printers and Faxes. Right click on the mp530, click Properties, Maintenance, Cleaning. Do a test pattern when requested. If it doesn't look correct, click Cleaning again, or Deep Cleaning.
Issue:
ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
The MP530 may require repair
Okay so I own this printer and I had this error. I did everything said on practically every forum out there and was ready to toss the thing. Then I figured, well I have some stock piles of new ink for this thing, they are useless now so I may as well try. I took out all the old ink cartridges. I wiped down the inside of the ink carriage. I made a point to wipe where the metal contacts were and where the ink came out. I turned it on, prayed, and pressed print. Now its working. So, no this is not your proverbial "death" error. You just need to clean the printer carriage and replace the cartridges.
Error 5C10, 5C00, and Error 6A00
Are purge unit errors. Usually this means something is stuck in the purge unit, or that the unit is broken or that the unit needs to be cleaned. This is the assembly under the print head when it is normally locked in its home position.
In our shop, we disassemble the machine, remove the purge unit and give it a bath. Reassemble and usually (80%) it works. Other times the purge unit has to be replaced.
Mergatroid
I did ALL that...to no avail...
THEN!!
I powered the thing on--and as soon as I could, I changed the setting from a bottom (cartridge) feed, to the back feed, all the while waiting for the thing to give me the death-error, but NO!!
I was able to quickly print my labels out from the back feed!!
BUT!!
I see that my death error is back, but at least, for now, I was able to print out those important labels..
Hope this helps!
SOURCE: Error message 5C10, won't print. Need locations
I think there was a broken pieces of hardware in the print carriage.
According to the Canon Center this one cannot be fixed. If your printer is under warranty, send it to them.
Read also this online user's guide for your machine.
www.yboyandrei.com/MP830_Err5C10
Please rate me if i am helpful to you.
SOURCE: Service Error 5C10
There's a couple things you can try:
First, make sure there is
no paper jam anywhere in the machine.. look inside, rear, where the
paper tray (output) is, etc to see if you find any shreds or torn paper
that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
Also, be sure that your scanner is UNLOCKED...
With the machine turned OFF:
Open
the document cover, look on the tray where the glass is -- and then
look to the LEFT side of the glass and you will see pictures of an
opened lock and a closed lock and a little switch...
Make sure the switch is next to the UNLOCKED position.
WAIT 5 seconds or so and then turn the unit back on.
If you STILL have the error code, try these two types of resets:
To clear the memory:
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is
not functioning as expected, it may be necessary to simultaneously
press Stop/Reset and ON/OFF buttons.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
SOURCE: service error 5c10
This error is a message indicating print head/ink failure on the printer.
I would try the following 2 things:
1. replace the ink cartridges/print heads. test to see if the problem is fixed.
2. If this does not solve the issue, you may need to either send it to the manufacturer for repairs (if under warranty), send it to a local repair person to service- or look for a new printer to buy (which may actually save you money).
SOURCE: service error 5C10
http://software.canon-europe.com/products/0010326.asp
uninstall the software and download the latest software from the above side and install it
SOURCE: Won't print - Screen message: "Service error 5C10
This is a VERY VERY common problem on this model. Usually this is a hardware failure - ( logic board ) which is not economical to replace compared to the cost of the printer.However, the main concern is Canon does not make this kind of multifunctional machine anymore, which combines print, fax, scan and print to CD/DVD.
There are few tricks that might work. The tricks are mentioned below :-
A)
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
B)
Open
the machine and remove the ink cartridges then look inside with a
flash light and make sure nothing is in the path of the carriage.
Then turn off the machine and wait 30 seconds. Turn it back on and wait
for the insert cartridge message. Then reinsert the cartridges into the
machine.
Then move the cradle back and forth a few times manually by hand.
Then close the cartridges access door and turn the machine off.
Then unplug it and wait 10 minutes.
After 10 minutes plug it back in and turn it on.
If this does not solve the problem, you need to send the unit for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Hello and Welcome to FixYa!
Error 5c10 is ink absorber problem.You need to reset Printer Canon ink absorber. For this Follow the steps given below
I have the same error code for my MP830! How do I fix this?
I was trying to print something, and it kept popping up on the screen that I had a service error 5C10. I tried wht they said, and turned the printer off and then on again, but with the same result. I checked the ink cartridge holder, and none of the ink cartridge lights were on. What can I do to fix this? I really need my printer.
Thanks,
Mzzperk
6 a00
"I was trying to print something, and it kept popping up on the screen
that I had a service error 5C10. I tried what they said, and turned the printer off and then on again, but with the same result. I checked the ink cartridge holder, and none of the ink cartridge lights were on. What can I do to fix this? '
Same exact problem and attempted solutions here as well.
yes I am getting this also!
When I try to print the Alarm light flashs and will not print,Service Error 5C10 comes up. What can I do to fix this prolblem?
Should I just buy a different brand?
This is a Canon PIXMA MP530.
intermittent 5C10 error message. alert requests i cancel the print job and turn printer off. which i do. this will occasionally rectify the problem, but i've been getting the error with increasing frequency in the last week.
"Service Error 5C10", I have tried shutting down printer but still the same when I turn back on. Please help
same problem
