Element Electronics FLX2211B 22 in. LCD TV Logo
Posted on Dec 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My flx-2611b elements tv stopped working today. the power light does not come on now. Is there any way to reset this tv?
Joaquim Martins
Level 3:
Genius:
  • Master 1,128 Answers
  • Posted on Dec 20, 2009
Joaquim Martins
Master
Level 3:
Genius:
Answers
1128
Questions
0
Helped
298178
Points
3333
This a defective board, psu or inverter board, need to be checked. send to electronics repair store.
How do you remove the face of the element flx-2611b to replace the speakers?
Remove the back and you should be able to get at the speakers
No sound on tv
Under the menu option try factory reset..... then try the audio source, but the factory reset should fix it unless you are using a separate sound system.
1helpful
2answers
Element electronics tv model # flx - 2611b bad
Try ShopJimmy.com - they have a huge stock of TV parts. They are used but tested meaning they are usually much cheaper option and often have parts that are no longer available.
Power board: (verify correct part before ordering)
http://www.shopjimmy.com/polaroid-860-az0-mlt666amh-power-supply.htm
Picture of above part:
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj860az0mlt666amh.jpg
List of available parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=element+2611&stock=all
You should verify the part number from your original board before ordering and also visually check that the replacement part matches your original. The part number is usually on a barcode sticker on the board or printed on the board itself. Be careful here as the number on the board may be the board number so try the find a part number if possible - the same board can be used for various configurations of components so is not a guarantee of being the correct part. Also manufacturers sometimes use different boards in televisions with the same model number according to price/availabilty/reliability.
You can also verify stock, part number, etc by contacting the supplier first. They may also be able to help you if you can't find your part on their website.
http://www.shopjimmy.com/contacts
Alternatively, once you have identified the part number, search for other suppliers by entering the part number into Google or Google Product Search. Be sure to enter the part number with any hyphens, spaces or periods as it is written on the board and if you have no success, also try the same search without any punctuation, e.g just the numbers and letters with no spaces.
http://www.google.com/products
Hope this helps.
Regards,
BElectric
2helpful
Element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
I possibly had a surge on my Element FLX-3711B Tv. It was also connected to a sony surround sound station. The sont was off for a while but reset it self after awhile and now works fine. My TV has not...
Tv now have LED indication power light on the screen panel blinking light or totally dead,no light at all?The power supply board,that the board where the power a/c cord plug into it.That the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
2answers
Element FLX-2611B won't turn on. The red light is not lit
Just because fuses are intact does not mean it is not damaged. Sometimes a small spike of power does not blow a fuse but damages Transformer windings Before the fuse! If there are no lights picture or sound think powersupply transformer primary.
5helpful
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
