I have a Sony KV-32XL90E3 years old.It has a problem:there is sound but no picture and the Stand By/Timer light blinks 5 times,pauses and then does it again.Could you help me to find a solution?
Light blinks 11 times when i try to turn it on with remote control on Sony Trinitron tvLight blinks 11 times when i try to turn it on with remote control on Sony Trinitron tv
ya,we r facing the same problem,when we trying to start the t.v,then a little light on the bottom near main power switch start flashing,i try 100 time by remote and by t.v switches,but i don't take success.plss help me to sourt my problem.thank u,ya,we r facing the same problem,when we trying to start the t.v,then a little light on the bottom near main power switch start flashing,i try 100 time by remote and by t.v switches,but i don't take success.plss help me to sourt my problem.thank u,
AnonymousJul 05, 2008
tv will not stay on and blinks 5 times in stand/timer position.tv will not stay on and blinks 5 times in stand/timer position.
I have a Sony KV-32XL90E 2 years and 4 months old. It has a problem : there is sound but no picture and the Stand By/Timer light blinks 16 times,pauses and then does it again.
Actually starts with sound and after 2-3 seconds stops and the stand by led flashes 16times.
If I try to switch on/off the TV by remote on several times, it may work. And then, if I switch it in standby and on again, it will doesn”t work. What else could I do? Could you help me to find a solution?
If I try to fix-it by myself what shall I do ? I have a Sony KV-32XL90E 2 years and 4 months old. It has a problem : there is sound but no picture and the Stand By/Timer light blinks 16 times,pauses and then does it again.
I have the same problem whit the SONY WEGA KV-32XL90E and I woud like you to help me solve it if you know how!I have the same problem whit the SONY WEGA KV-32XL90E and I woud like you to help me solve it if you know how!
You can't post conmments that contain an email address.
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Would you like to tell me about stand-by light condition when TV goes to Off/ shut-down? How many times this light blinks?
Actually light-blink gives feeback about problem area. You can say it Error Code.
IF--- You have 3 video ics located on CRT broad # TDA6111Q ,if only one of them is shorted set will not come on these ics will kill the high voltage, there for keeping set off.
I have a SONY WEGA 3 years old KV-32XL90E and have the same problem the Stand By/Timer light
blinks 16 TIMES, pauses and then does it again.The sound is but no picture.
your problem in system control ic section related to stand by pin
check ckt related to stand by section in remote ic
check power to system ic
loose coniact in remote or system ic
thanks
Actually starts with sound and after 2-3 seconds stops and the stand by led flashes 16 times.
