If your MP3 has an inbuilt Li-Ion battery (e.g. no compartment for a standard/Ni-MH AAA battery), then connecting the player to your computer will normally charge it - this is the case for the PD-6070 'stick' player.
Your player will also indicate that it is being charged (or not charged!) via the battery level/power indicator which is located on the top RHS.
Hope it helps!
yes, plugging it into a usb port (either through a wall charger or a computer) will start to charge the mp3 player. an indicator that it is charging should show up on the screen.
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
Yes most mp3 players automaticly charge when you plug in to down load from your computer. All you need is the cord not the software so any pc can charge the mp3.
I PLUGGED IN MY MP3 PLAYER TO THE COMPUTER AND THE SCREEN ON MY MP3 PLAYER LIGHTS UP BUT the normal screen image for when you normally plug it into the computer ISN'T THERE AND I CAN'T ADD MUSIC ON MY MP3 PLAYER.
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do... 1. plug the payer into your USB port. or wall charger 2. switch thje player on 3. turn it off by either holding down the play button, or selecting
"System" from the menu 4. The screen will go black and the battery will begin charging.
One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
