Epson Stylus C60 InkJet Printer Logo
Anonymous Posted on Jan 23, 2008
Epson C120/ Stops at Perforated line
I have an Epson C120 Ink-Jet Printer that stops printing at
Perforated sections. The printer is new and I've cleaned it
and adjusted paper quality settings. Am considering returning it.
Any advise?
  • Anonymous Dec 19, 2012
    Make sure that you use the right type of paper and that you stored them properly. Also when feeding the paper, make sure that it's fitted snuggly in the tray. Check your toner cartridge and transfer roller too. Learn more basic troubleshooting here.
monk3ybidzness
Level 3:
  • Epson Master 1,879 Answers
  • Posted on Jan 23, 2008
monk3ybidzness
Epson Master
Level 3:
Answers
1879
Questions
Helped
763870
Points
4784
The sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Bright White Paper
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Paper Glossy
Epson Photo Quality Self-adhesive Sheets
Epson Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-sided
Epson Presentation Paper Matte
Epson Ultra Premium Photo Paper Glossy
Level 1:
Problem Solver:
  • Contributor 28 Answers
  • Posted on Dec 28, 2014
Contributor
Level 1:
Problem Solver:
Answers
28
Questions
0
Helped
11118
Points
45
C120 is not a new model.
the problem is that the pw sensor(under the cr assy) is dirty with ink and it cant read the paper.you have to clean the sensor and try to clean the cable of the sensor
Epson 7010 all lights flashing & won't print
Epson printer blinking different lights. The different lights blinking has different meaning and solutions. When the Epson printer red light blinking that means ink cartridge of your printer is out of ink. And when your printer green light blinking that means paper gets jammed inside the printer.
You can fix the Epson printer lights blinking error using following steps:
·Fix the paper jammed
·Check empty or damaged ink cartridge
·Clean the dirty print head or replace missing or failed print head
·Read the steps to fix the Epson printer lights blinking error.
Horizontal lines on page
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
New ink, printer's status is "ready", but it gives out blank pages. The machine acts as if it was printing with clear or invisible ink. Looks like it's doing its job, but you don't see it. Thank you
if you don't use the ink jet printer for some days its head goes dry and the ink not come out of the cartridge,its solution is to open your dry head nozzles and then print
HOW DO I INSTALL MY EPSON C-120 PRINTER WITHOUT A DISK
Hello, you will need to download your drivers online, use this link to download your drivers directly from the epson website:
Epson Stylus C120 Ink Jet Printer Driver
Choose your operating system and click go to view available drivers. Click the plus (+) sign next to your driver and then click download
Thanks for using FixYa
Printer will not print clear or lines missing. Went through with nossle check and head cleaning but still do not print clear.
OK, you're going to have new ink jet cartridges to start with. I know they are expensive, but missing lines is a telltale sign of depleted ink. One may only be able to get 100 printed pages on avg. out of ink jet cartridges for consumer models.
Try original equipment manufacturer cartridge, in this case Epson cartridges to ensure quality output, and trouble free operation.
Make sure you align cartridges to get clear printouts that are calibrated properly.
Good luck on this repair.
1helpful
I get a double image with my Epson c120. I replaced the color ink cartridge for about $49 in order to be able to print black and white text but I get this almost unreadable output. Any suggestions?
try doing print head cleaning.. the feature is under the printer properties , utilities tab... then once done.. print a copy of nozzle check..see if there is any missing line..
It won't print after installation of new ink jet
Here's a link to the Epson printer troubleshooting guide...if this helps; please indicate so.
http://er.epson.com:8001/start
Paper goes thru printer without printing
Look if you do the paper correctly in the printer and if you have enough colour to print then it should go^^
C120 Installation Problem
call the manufacturer immediately for ink replacement.
3answers
Printer problem
on photos, If you have a laser printer with half a meg of RAM and you try and print a full page graphic at 300dpi you only get half a page because the printer runs out of RAM. You can get a full page by printing at 150dpi. could also be that the encoder strip has become fogged with aerosol, and needs gentle cleaning. Good luck
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
