How i reset the Sansa Clip, no, i'm not asking about the "holding power up for 10 seconds" method, i'm asking about the "small pinhole" method, how do i know i'm touching the right part i have to press in the "small pinhole" method?
For sansa clip, there is not "small pinhole" to reset. A small hole you see on the cover of the device is microphone for voice recording only. To reset device, you have 2 ways
1. Normal reset: Settings >> reset >> yes
2. Hard reset: press and hold power button for 10 to 15 seconds.
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Instructions
Complete Reset
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.) .
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings How to Reset a Sansa Clip The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Instructions
Complete Reset
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
For the Sansa Clip, first try to RESET the player:
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
If the player still freezes with the refresh database message, after a reset:
then update the firmware. Next link shows how to update the Sansa Clip: http://kb.sandisk.com/app/answers/detail/a_id/300
In METHOD 1 is explained how to use the sansa updater, for Windows operating system.
METHOD 2 tells where to find the online sansa forum for updating manually.
Reset is to restore all your router settings to default or Manufacture settings like when you newly bought it. The reset button is at the back (pinhole type); Press and hold for 10 seconds Properly* with a pen or Paper clip. Release and turn of the router 30 secs and that should do it . All Current settings Gone.
Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds.
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer’s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
or
try reseting the device its usualy a small pinhole on the back or side of the device try holding that in for about 10 seconds
try reflashing the firmware for your device you can find the latest firmware and flashing utilitys from the manufacturers website
