It sounds like you may a faulty door lock switch. If you pushed the switch to lock the doors and the switch stuck and kept door lock solenoids energized, that would drain the battery. It would also keep the door locks from unlocking, as to why window don't work it could all be on the same fuse or circuit breaker. Usually the power windows are on an automatic reset circuit breaker. Do you hear click and a short time later another click (with the battery charged)? If so that the circuit breaker tripping then resetting. Good luck!
Where is the circuit breaker? Is it the two bolt piece just inward of the fuse box on the side of the fuse box?
I've got the same problem I thought I had it fixed but the "check engine" light came on. I replaced the battery and the check engine light went off ,but now the door lock and window won' t work?
SOURCE: 2005 Colorado drivers side window and remote locking system
Just figured it out and replicated it 3 times..
any type of power/voltage change seems to trigger this issue
The most common symptom is power locks fail and only the driver window quits, however that is on the extended cab.
Steps to fix and it works every time.
take door panel off driver's door
Disconnect the wiring attached to window and power lock control unit
disconnect battery cables
connect the negative to the positive cable(((NO BATTERY CONNECTED)))
This will act to short residual voltage in the system
5 minutes later
place the key in the ignition and turn to the run position
connect the wiring to the window/lock controller
connect the negative cable to the battery
then the positive
open drivers side door
turn key to the off position((do not remove yet)) you should get a series of dings through speakers telling you the key is still in the ignition
once it begins dinging pull the key out and you should hear the door lock solenoids trigger and the windows should work.
Three years and a very unhappy girlfriend who owns the truck. but she's happy now.
