Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
Maytag Quiet Series 300 dishwasher leaves sediment on dishes (primarily glasses) after running the Autoclean cycle. We've taken it apart, cleaned spray arms, filters, float and replaced some seals, but still have problems. We use Cascade detergent and Jet-Dry (what was recommended when we bought the dishwasher). Our water temperature is 120 degrees (maximum setting we can have without having our tankless water heater modified), but this dishwasher problem was an issue with our old tank water heater, which had been set at 130 degrees. Any suggestions on how to rectify this problem, or is this just a poor dishwasher?
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Posted on Feb 05, 2012
    Scholar:
  • 93 Answers
The propblem sound more like a rinse aid problem not the product but how much.Try useing a bit less or set the dispenser to release less this usually solves the problem let us know how it goes
Posted on Dec 28, 2009
SOURCE:
Maytag dishwasher legacy quiet series 300 clean light stays on after cycle is over
That light will remain on until you remove the dishes that are in there so that you know what is inside is clean and not dirty.
Jul 04, 2017 | Maytag Dishwashers
How should I clean the Maytag Quiet Series 300 with vinegar?
just fill it with water no soap and drop in vinegar right in the water and let it run its cycle
Jan 27, 2015 | matag Maytag QuietSeries 300 Dishwasher...
Our Maytag Quiet Series 400 has stopped getting the dishes clean..It leaves residue and food on the dishes.My husband has taken it apart and there is nothing that he can find that might cause this.We have...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
May 03, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 | Dishwashers
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag dishwasher legacy 300 quiet series
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Maytag quiet series 300 - sandy residue
the buttons to start the cycle auto clean or heavy wash does not light up and therefore is not cleaning my disches please advise to
Carol @ killday@irtc.net
Apr 06, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
735 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
