I have a Samsung SP47W3HFX tv which is a rear projection and my picture has gone wrong. I have read numerous bloggs on the issue of convergence problems, but i am not sure my problem applys to this.
My problem is Blue curved flickering lines on the screen( I have tried auto focus and manual convergence neither of these have helped) If you take the back off and look into the coloured guns the red and green gun are perfect but the blue gun is flickering and the lines are curved...!! Is my problem a lamp fault, projector problem, convergence problem or something else??
SOURCE: Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
SOURCE: Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
SOURCE: sony rear projection convergence
This is a convergence problem that is either bad connections on the convergence ICs or defective ICs. IF you can solder and feel comfortable working inside the set, you can fiox this yourself. Let me know if you wish to attempt the repair and I'll post more details and instructions.
Dan
SOURCE: convergence Issues
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
SOURCE: Arched blue lines across screen of Sony 63" Rear Projection TV
Had this problem bout 2,3 years ago...it was fixed in about 5 minutes with the help of this article
Tonight I have to do this fix again..the blue lines came back about a week.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I strongly urge you to save the web page locally on your hard drive or print it out and place with the tv manual....
Good Luck..
