Compaq Armada E500 Notebook Logo
Anonymous Posted on Jan 23, 2008
Laptop compaq armarda notebook can not get connected to internet
I have a compaq armada E500 series and i am unable to conect to the internet with the wireless card even with a ordinary modem attached it wont go onto the internet.
I have had it connected once then suddenly it said web page unavailble can not find server m since then i have not been able to go onto the internet with it my other laptop is fine and so is the larger pc its just this one laptop that wont connect.
julie
  • 1 more comment
  • Anonymous Jan 23, 2008
    How do i upgrade internet explorer i know this sound very silly buti am no computer expert
    julie
  • Anonymous Jan 24, 2008
    the laptop in question is a windows office 2000 everytime we try to connect it says server cannot be found the wireless card itself says its connected to thei nternet but the laptop say not and says working off line.
    julie
  • Anonymous May 11, 2010
    xp or vista?..
DENNIS MITCHELL
Level 3:
Genius:
  • Master 1,003 Answers
  • Posted on Jan 23, 2008
DENNIS MITCHELL
Master
Level 3:
Genius:
Answers
1003
Questions
0
Helped
367184
Points
2185
TRY UPGRADING INTERNET EXPLORER
I have a compaq armada e500 laptop as I connect to the internet
.... and your problem is ______________________________________ ???
1helpful
2answers
CAN I USE INTERNET THRU WIFI WITH COMPAQ ARMADA E500 ?
it seems like your laptop not have inbuilt wi-fi connection, so you can not use the wi-fi but if you buy a USB wireless adapter or wi-fi pcmcia card so you can use the wi-fi in your laptop.
Thank you for using Fixya
Regards
Manish
How can i connect a wireless internet connection with a compaq armada E500
Get a PCMCIA to USB2 adapter that has an external 5 Volt connection to it to supply the higher current for the wireless adapter. The power can come from the USB via USB adapter cable
After installing the adapter, the USB wireless device should be installed just like in any later notebook. The wireless device requires USB2 and high power. and won't work off a powered hub.
1helpful
How to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
2helpful
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
1helpful
How to charge battery in compaq armada e500
You need to connect the power adapter and charge it for some time and check.
Compaq armarda E500 and webcam
It will need a driver to work, but the machine shouldn't turn off or shut down. It should give a "found new hardware" prompt. It sounds like either the cam is exceeding the power output of the port, or the port is malfunctioning and needs repair.
The internet
i have my computer reformated. now i want ot connect to internet using dial up. i dont have my modem driver
2answers
Network card
Any type of PCMCIA network card should work okay.
Go down to Staples, Best Buy or Office Depot and find
a decent PCMCIA network card.  You should be able to find
one for under $50
Mike
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
