Started load then it stoped now it is just making a buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump. If nothing is stuck in the pump replace the pump. It won't spin until it drains, so fixing the drain problem will fix the spin. You can get at the drain pump by taking off the bottom panel.
I have a similar problem in that my spin cycle makes noise and yet doesn't move. Finally after a few more minutes it does spin but very slowly, even though I have the spin cycle on HIGH! Now What?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
If you hearing a buzzing noise it will be a faulty relay (for the water valves) its (12v.DC 10amp Black ones) on the board, I know its happen to me also what I found is the main board in the back had some solder dry joints on it to. Hope will help you all..Michael
