T.V.was working good,turned off ,went to turn back on and nothing,no sound,no picture.There is a click and standby led blinks 4 times.Went through troobleshooting from Sony but nothing changed.I have a Sony kp43t75.
What is the make and model number of your set? I can help you but I need that info, So I know where to start.
Can you hear the relay click when you press the power button?
If no check the fuse, If fuse is good and you don't hear a click. Its no doubt your relay as this switches your power one path to stand by an the other through the line coils and on to the various regulators to start and operate the set. Let me know what you find and what sounds it makes if anny. Listen for a soft tick tick sound when power is pushed.
Tomorrow I will post some things to check so you should be able to pinpoint exactly whats wrong with your set.
You're welcome wil post in the morning.
toshiba 55H70 55 in. Rear Projection Television
if i unplug it and plug it in. it makes a clicking noise. but the only thing that happens when i press power is the light pauses momentarily.
ok thank you very much
I have the same problem.
