PANDIGITAL (DPF802) Digital Picture Frame Logo
Posted on Dec 18, 2009
My pandigital frame is only letting me load 85 pictures
My pandigital frame is only letting me load about 85 pictures and then saying there is no more free space. It shows about 888 MB available at the bottom of the screen though.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Dec 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1092
Points
6
How big our your jpg pic files?
reduce them to 800x600: sh hold about 200+ pics.
also delete the pics that were pre-loaded
fred
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
459
Points
Just making sure that you are loading all your jpeg photos into a folder, then drag the folder into the memory device.........
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
19379
Points
Resizing doesn't help. It sill has the problem.
How do you load pictures on a pandigital picture
Hello there,
The Pandigital picture frame saves its image files on the memory card. You can put pictures in memory card by inserting it to a memory card reader on the computer and copying pictures to it. Tthe picture frame, then reads the files on the memory card.
Should you need further assistance, please let me know. Thank you for using FixYa.
3helpful
How do I connect a flash drive to my picture frame?
Let me get this right. u r saying u want to connect a flash drive to a normal picture frame??? :S
Trouble playing video on Pandigital picture frame
Have you looked in the manual to ascertain which movie formats and sizes are supported by your equipment ?
Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
How do I load my photos on a pandigital picture frame?
I could not load my directly directly from PC. I had to put them on my camera memory card, then insert memory card into frame. worked well but took more time.
SD Memory Card in frame-no pictures
1st: Make sure the SD card is in working order and not damaged.
2nd: Make sure you're using the right file type (.jpg, .png, .gif, etc) and size.
1helpful
Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Top PANDIGITAL Photography Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
