Recording
It will record any line level source (CD, MD, tape, tuner). You can only record vinyl records if you have a phono pre-amp.
The best way to use a CD recorder is to use the "tape loop" on your amp/receiver. Does your amp/receiver have a "tape in" and a "tape out"? If it does you should connect your CD recorder to these in/outputs. That way, whatever your amp or receiver is set to listen to, is what you'll be recording.
Shout if you need more help!
how to record from Deck A to Deck B
how to record from deckA to Deck B using koss cdr200
