Microwave Ovens Logo
Posted on Dec 18, 2009
Maytag microwave timer counts down super fast,not heating
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2271
Points
7
I had the same problem with my Maytag Microwave. All I had to do was unplug it and plug it back in to fix. Good luck.
1helpful
Timer counts down very fast
The keypad control board will need to be replaced, bare in mind the cost for the part will exceed the price of a new microwave oven in some cases.
2helpful
Timer runs super fast, I dont think its heating at all. set for one hour, takes only a few seconds to run. Owned since 2003
I have a Maytag that did the same thing. I unplugged it for about 2 minutes, plugged it back in and it is working fine.
Our microwave is not heating and the turntable is also not working. When I try to cook something the timer starts counting down but nothing else happens.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
3helpful
2answers
Microwave timer counts down super fast
try unplugging it for about 15 minutes. if that doesnt work, you might as well get a new one. i fix everything myself for just the cost of parts and i have found that what parts cost for a microwaves, its cheaper just to buy a new one.
1helpful
Time count down on microwave oven
Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
10helpful
Timer runs fast, plus no heat Maytag MMV1153BAW
No... you are not in a microwave induced time warp...
Your microwave oven needs a "reboot". The same thing happened to me.
Unplug your microwave oven, wait about a minute (more or less), plug it back in. Try setting/running your kitchen timer, boil water, etc. Your timer software on the microwave should be reset.
1helpful
Timer descends very quickly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
4helpful
The timer is running fast. It counts down 1 min in 5 sec. Clock and other functions appear to be working ok.
The unit is set in demo mode, Check your owners manual for instructions to get back into regular mode.
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
