SOURCE: oven controller not functioning
9.
The time of day does not display on my electronic oven control. If I
push the CLOCK pad on the control panel the time will display for a few
seconds and then it goes blank again.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Push and hold the CLOCK keypad. The time will
appear for a few seconds, and then disappear and finally it will
reappear and beep. Release the keypad and the time should continue to
display. Follow this same procedure to turn the time display off.
SOURCE: clock displays time but can't be set. can't use
sounds like your control board is bad sears.com type in model number should get price on board. unplug stove take back of upper panel off you will see board should be afew screws and some wiring plugs easy to change
SOURCE: TEF326 Oven stopped working, range works ok
Could be the over temp thermofuse at the back of the oven. (TOD) Especially if you just did a self clean. It gets up to 900 degrees and can trip the TOD. It will have to be replaced as it is not usually resetable.
