What oil, how much oil, and how do i change oil on a pressure washer pump ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
There is a plug on the bottom of the motor, it may be located as part of the fill spout(where the dipstick is) drain and fill with 5w30 generally it is found in the owners manual, but if you dont have one just start with half a quart, check the dipstik, then add more until it is at operating level.
