Insight cable is digital and you have a analog tv thus you may need a box in order to get such signal from the digital cable system as you analog set will not sense the signal being pump threw the line. I would call insight cable and ask them to come ans look at your setup there. But you could run the channel setup from your remote and try to rescan but i think you need a box.
Thanks I hope this does help please do click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Typically the cable box is the source of your channel programming. If you're getting the "no programs available" you need to find if that notice is from your TV or your cable box. Check the connections from your cable source to the cable box and from the cable box to your TV.
Make sure that your TV is set on the proper source selection. Most Projection TV's have several (ant, cable A, B, DVD etc) check your on-screen menu for which one and make sure the cable is connected to the proper input ports on the back of your TV.
If you disconnect the cable between the tv and cable box and still get the "no programs "...then it's your TV.. but if you lose that warning, then it's coming from the cable box... If after checking your connections, disconnect the power to your cable box and let it sit for 5 minutes and then reinsert the power to the box and see if you get a reset with signal...... If nothing after all this, contact your cable provider to check their signal to your house and also the cable box.... Hope you have quick success on this!
nothing..still can't get a picture....this is so simple a lst grader can do it...but what to do?>
I turn TV on with cable remote and tv remote..all I get is ...nothing...but a 4 on TV screen and nothing on cable remote...a 4 in cable box window..but tjhat's all... I have a standard hook up...as far as I kknow...,my wife has never disconnected anything to get a
picture...but I'm stuck...I am convinced it's all in correct remote signals...but what are they?
