Dell E153FP 15" LCD Monitor Logo
Posted on Dec 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power indication screen dark - Dell E153FP 15" LCD Monitor
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Dec 19, 2009
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366816
Points
33650
Check power supply for bad caps, check transistors (C5706/5707) for shorts in the inverter circuits.
I have compaq MV7500 COLOUR monitor n when i turn on the screen then i m getting only white line in the middle on the screen how can i fix the problem
When the following conditions, you need to replace the LCD screen:
No image on the screen, but the power indicator stays in
Dark display but still readable
Results - 1 of 1 / from by by 2 to a few seconds are of the the the the scintillator of the screen and Close for between the
The power indicator has been lit, but nothing display and sound
No image on the in the screen, but the LCD TV still comes with audio
Pictures cycle open and close the, as well as lamp closed for non high-power LED
http://www.lcdinverter.info/hp-pavilion-dv61247eo-lcd-inverter-p-11136.html
My screen will not come on
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info
3helpful
Acer screen looks dark?
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
1helpful
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
2answers
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Monitor problem.
This just happened to me last night.  My web research indicates that the monitor is bad...others have had the exact same problem.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
