Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My datatraveler 64gb dont formating in my
My datatraveler 200 64gb dont formating in my computerand my system dont see at flash driver from kingston. what i doing???
Datatraveler dti.4gb ""the disk in drive E is not formatted" how to solve my problem
Posted on Feb 14, 2010
SOURCE:
I purchased a Kingston DataTraveller 64gb hyper x 3.0. It works find on my notebook with windows 7 - fine on another notebook with Win xp - but when I plug it into my desktop system it flashes once -...
try going to this link might be something very simple but they have good information. http://www.kingston.com/en/support/technical/products?model=DTHX30 could be a case of being a usb configuration problem
Oct 20, 2013 | Kingston Computers & Internet
Kingston DT200/128GB not able to detect
Go to your Admin Tools, computer management, disk management and if it shows up there but with a black line across the mini window it showing in, it will need to be enabled for windows to see it. if nothing like that is working, it may just be a bad drive. kingston 128Gb flash drives may not be formatted correctly for windows to see that its plugged in
Oct 18, 2013 | Kingston DT200/128GB 128GB DataTraveler...
What is an I/O device error when trying to access my kingston Datatraveler g2 Flash drive and how to fix
the i/o stands for input/output device and the flash drive is one of them,try formatting the drive on another operating system like ubuntu
Sep 17, 2013 | Kingston DTIG3/32GB 32GB DataTraveler G3...
How can you wipe a kingston 64gb data traveler
click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps
Oct 14, 2012 | Kingston 64GB DataTraveler 200 USB 2.0...
I don't formats my kingston 64gb pen drive
Hi kingkumarae,
Due to viruses , the drive cannot be formatted in many cases, however if you want to format it ,
I would recommend that you restart your computer and plug in the pen drive and then do not autorun it.
When you do that , you can right click on the drive that you find in my computer and then rightly click on select format option, and then you can format your drive.
If this does not work in your computer you can possibly try it in your laptop using the same procedure.
Hope this helps ...:)
Sep 04, 2011 | Kingston DTU30G264GB DataTraveler Ultimate...
I have a kingston datatraveller 200 64GB. I cannot access it and I get the message 2233 Pram. HOW can I read my files?
You can not. This is a damaged Flash Drive. The portion of the chip that holds the programming has become damaged. I had the exact issue. It had to be sent to a level 3 recovery company. Like ADR or Ontrack. I used ADR. Then you can send the device to Kingston for a free replacement but Kingston will NOT do a data recovery for you.
Jun 17, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Uploading to kingston data traveller 64GB corrupts my files
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 27, 2009 | Kingston Technologies 512MB DataTraveler I...
I can't format my 2gb kingston data traveler 2ntfs and it stores only less than 28 mb. i can only use this data traveler on my microsoft office word and excel files but about my audio files, all could be...
I have kingston datatraveler 200 (64gb) and I backum 4gb`s on that usb, but when I want to opet that, its corrupted, damaged and now I cant even format my usb.. help
Dec 18, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
64GB Kingston DataTraveler won't format
Try using someone else's computer to format it. If that doesn't work .... then it sounds like the drive itself has sustained physical damage. I would contact whoever sold it to you and ask them for a Return Merchandise Authorization (if you bought it recently) because it is probably dead.
Jun 12, 2009 | Kingston Technologies 512MB DataTraveler I...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
1,365 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
