How do I change the time and date reflected on the display?
Hit the feature button (gray, looks like a globe on it) under the display, under the 3 gray buttons in a row.
then **8463
password is 23646
follow prompts :)
hit the hang up (phone with arrow underneath) when fone.
Samsung
Digital phone systems... including DCS, DCS Compact, DCS
50si, DCS 400si, iDCS 500, iDCS 100, DS 616
And
Samsung Voice mail systems... including SVMi-4, SVMi-8,
and Cadence.
This is a multi-step
process which involves entering administrator level programming and then setting
the date and time. Programming can only be done from a 12 or 24 button
display telephone.
Press TRSF and then dial 505.
The display then shows the current date and time setting on your system.
The example below shows Monday, April 7, 2003, 9:30 AM.
NEW:WMMDDYY:HHMM.
W= Day of the week (0-6; Week begins on
Monday and ends on Sunday)
MM= Month (01-12)
DD= Day of the month (01-31)
YY= Last two digits of the year (01)
HH= Hour (Use 24 hour clock and enter
the range of 00-23)
MM= Minutes (00-59)
Press TRSF to store and exit
programming.
If you have entered invalid data, you will receive an INVALID
ENTRY message for three seconds.
Reenter the date and time.
To change the date and time on the Merlin MLX-20L:
press menu
press System Program
Press Exit
Press System
Press Time
Enter the time
Press Enter
Press Exit
Press Home to exit programming mode
To change the Date:
Press Menu
then System Program
then Exit
then System
then Date
Enter date
then Enter
then Exit
press Home to exit programming mode
I downloaded and printed the Users Manual and there was NOTHING this clear and concise in the manual....
spent 40 minutes searching the internet to find this solution!
and it's so easy...that I now I feel like so ******
I had a wonderful time searching online for the same solution, without
any success. All I did was call myself from a different phone line and
the date and time changed automatically!
Hope this works for you!
Terry
Feature
00
*phone lights up
left intercom
left intercom
*system program* (onscreen)
#101 for date
#103 for time
To Change the date
Hit "Feature" 0,0
then hit left intercom button 2 times
then type #101
type in date ex 102508
they hit "Feature" 0,0
You can only change the time on the primary phone in the system. You need to find out which one that is and change it on that one and the rest should change. Or just try it on all the phones connected to the system. It will work on one. Then that's it.
Change time of day
Have a comdial 5 phone system and no instructions in the manual on how to change the time in the display?
Press 'Prog' then press star key twice, then enter '1234', then enter '000', will get you to Date & Time Set, then press 'enter' button (bottom right hand corner of phone), this will then allow you to change the date and time accordingly.
Hope all goes well
Remove the batteries, and the power cord, wait for the LCD screen to go blank. Re-insert the batteries, as soon as you put in the last battery, look at the LCD screen. You will see a display massage. Hit the up/dn arrow on the round key which say Del. -- Dial/Opt until you see set time. Use this same key to set the time and date. Hope this help you.
Http://www.also.com/panasonictimechange.htm
This has step by step instructions. Good luck!
SOURCE: Need to change date on phone system to reflect correct time
OR, you could go to the programming phone and program it yourself.
1. Press Menu
2. Press System Program
3. Press Exit or Start
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
To Change the Date and Time:
To Change the Display Fomat:
How to change the time and date on the display?
how do i set the time? change the time?
i have a southwest bell freedom phone FM2552B that i can't set the clock or date on......
I have the NEC Electra Professional ETW-16DC-1 and have missplaced my manual. Do you know how to change the time on the display?
I do not know how to change the time on my phone lucent partners 18D
I have the same phone and I wrote down how to change the time as follows: FNC, then 9 #, then change time, then FNC but it doesn't work. Is there another way of changing the time?
How do I change the time on my Lucent MLX-20L?
need help on how to change time of day
How To Change Time & Date?
Set Time On Computer
dont know how to set the date and time...help?
Lights went out and we can't figure out how to set the time on our phones
time is ahead by like 40 minutes. can't figure it out!
can't seem to change the time, keeps asking for user ID
Date displayed is not correct-how do I change it?
i cant not get the date to change
TIME!!!???
