Need to know how old a computer it is as over the years the power supplies' use different methods of starting.
On newer computers the power supply is connected to the mother board by a 20 or 22 pin connector. The power button on the computer is just a momentary switch to start the computer. Make sure the large connector is firmly seated in the mother board. If you are comfortable with doing that have someone else check it. You do not want to damage the connector or mother board. You need to have some sort of anti static device conntected to your body to avoid any static discharge that could damage the mother board.
Hello Friends, If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
open *********** board battery some time or " mother board battery inside
3pin jumper switch. open this jumper middle pin to other pin connect
some time 1 minute & jumper set previous position. or" see mother board battery inside reset switch
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
