Music Logo
Posted on Dec 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a marshall dbs 7400 bass head, both the deep and bright switches are faulty. i have purchased new switches and want to know if i need to get a tech person to fit or are they easy to fit and i could do it myself. cheers steve
Anonymous
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Dec 29, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
62160
Points
212
If you feel confident and you are experienced in soldering you should not have a problem. Otherwise take it to a tech. That shouldn't be more than $30.
If you do it yourself be sure to discharge the filter capacitors. They can electrocute you.
My Marshall MB4410 Bass Amp has issues when pulling strings when slapping
A silly suggestion is to plug in a different guitar and see if the problem still happens. Have you checked the link your using to connect to the amp? For example is it a faulty lead, a loose jack plug on the end of the lead or an intermittent signal from a wireless connection? You could also check the pickups on the actual bass guitar.
Pick ups don't often cause issues but they can become faulty because of age, corrosion, short circuits and if they're badly fitted.
Jan 06, 2022 • Bass Music
What is the modern replacement speaker for Marshall 27115 bass combo
You would be Seamus?
Eminence are not a high-priced speaker. You could replace it with one of the bass guitar speakers here, like the large magnet CB15
http://www.usspeaker.com/15.htm
Sep 26, 2016 • Bass Music
Marshall 600 silver series bass amp head
Hi, what speaker do you have connected directly to the head? What output are you using to go to the PA?
Dec 19, 2013 • Music
There is no sound coming out of my Marshall 100 watt tube amp head?
make sure the standby switch is operating correctly.Sounds like the power tube.
1helpful
Does anyone know how to make a bass knob remote out of phone line? What the color code? I have 4 different color wire here but i don't know what to do to make a bass knob remote.
It is NOT clear what you are trying to do... HOWEVER if you are attempting to extend a bass potentiometer remotely, you CANNOT use the four wire flat telephone line as it is unshielded and you will pick up hum.
2answers
Can i fix one ampli marshall mg100 i had used my bass, and now my marshall have a very estrange noise
Well i know ive destroyed a guitar amp with a bass guitar before :-p this is why they make bass amps and guitar amps instead of just amps
Is there a way to mod the hd100fx head for more bass?
You are ultimately limited by the available power of the internal amp. You can set controls for bass boost and turn off the treble but there is only so much power available.
HINT: If you are using speakers smaller than 15 inch, that will limit the bass as well. Use larger efficient speakers.
Top Marshall Music Experts
matt martin
matt martin
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Marshall Music Expert? Answer questions, earn points and help others
