Please can you help i am trying to find the remote sky code for an LG
32LC56 After going through hundreds of codes i am pulling out the remainder of what hair i have got left PLEASE PLEASE HELP.
Barry Y.
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
On your sky remote select interactive button, go too customer services and select option 5 , setting up sky remote, you should be able to find lg codes to try there. If not then try the internet for codes. You may have to wait though I didnt get my code for 6 months after getting new tv, but dont give up.
Code is 1293 if you're using a Rev 8 remote control. You can check this on the sticker in the battery compartment.
If you are using an older Sky remote Rev 6, Rev 4 or plain old RC1600/00 then it's unlikely to work as these remotes aren't programmed to control your TV. You are welcome to try though ;)
Please post back if you need instructions on programming the remote.
Please rate this solution if you find it helpful. Thanks.
you will need make and model of tv
turn on sky and press interactive on remote move down to sky customer services and select then move down to program remote and select and follow on screen instructions
hope this helps
MERRY CHRISTMAS
