I Have disconnected the batteries and have flipped switch back and forth to get trouble shooting mode #1 LED stays on.Shore line disconnected.
How can I get it to reset? [email protected]
Check all battery connections to make sure CLEAN AND TIGHT. If problem still occurs, disconnect all wires from batteries and showpower to let the capacitors drain fully (15+ minutes)... the longer the better. Then reconnect and see if problem still exists, and if so.. take to a service center
When I switch my Freedom inverter on it shows E02 fault Low battery voltage. I have had the batteries tested and they are okay.
When I plug into the mains to charge batteries the Chrgeheart interphase shows charging light but nothing happens No current.
If anyone could advise I would greatly appreciate it. Thanks
Ian
