Makita BL1815-2 18 Volt 1.5 Ah Compact Lithium-Ion Battery - 2 Pack Logo
Posted on Dec 16, 2009
The Makita BL1815 battery will not charge, lights flash red/green, indicating bad battery. I replaced one open cell with known good cell, charger still reads bad battery although I can charge from an alternate source when bypassing the too-smart circuit board. Can a bad battery message stored in memory in an I/C on circuit board be reset? Thanks, Tim A
kbert1171
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 12, 2014
kbert1171
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4350
Points
Tried it a few times. got the charge up to around 13.9 and it still wont charge. i dont understand, because the battery isnt that old to begin with. thanks for the suggestion.
5 Related Answers
A
Anonymous
  • Posted on May 23, 2008
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Soeren Danielsen
  • 3 Answers
  • Posted on Jun 28, 2008
SOURCE: Battery Issues
When Li-Ion batteries are discharged to a too low voltage (below 2,75 V/cell, in this case 13,75V) the charger will assume that the battery is damaged, and will not charge the battery. First measure the battery voltage with a volt meter, if the voltage is significally below the 13 V the battery are no good. If you have a reading of lets say around 10 V, you can raise the voltage shortly on the battery, by jumping it with a fully charged battery. Connect the "-" poles on each battery. After this, shortly connect the "+" poles, for no more than 5 seconds,disconnect the wires and immediatly put the battery in question in the charger. If it starts charging, every thing if fine. If not, try the process again, you might wanna recheck the voltage if it rises.
Please be aware, that over discharging Li-Ion batteries, will lead to damage of the Li-Ion cells, which results in loss in capacity, therefore, if you are not to use your Li-Ion tools for a while, make sure the batteries are fully charged.
Hope you guys could have sucess with the above
Best regards
Soeren
Avi
  • 66 Answers
  • Posted on Jan 10, 2009
SOURCE: MAKITA LXT BATTERY CHARGER
hey
flashing orange=cooling abnormality.
you need to wait for the battery to cool.
see my mod page, it has all light explanations in it.
Have fun
Avi
Robert Koch
  • 165 Answers
  • Posted on Feb 27, 2010
SOURCE: Brand new Makita DC18RA charger wont charge the batteries.
Return to store for replacement.
Anonymous
  • 843 Answers
  • Posted on Sep 03, 2010
SOURCE: When putting the battery in
Have you tried just waiting a few minutes, it might start to charge anyway. But if not, is there some reason you would assume that you don't have a bad battery? There are lots of bad Li-Ion batteries.
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 • Drills
open battery case and look for corrosion clean with baking sodas
2answers
What does it mean if the red and green light are on at the same time on the charger
If the red and green lights are flashing, the charger is detecting the battey has a defect and is not safe to charge. It could be one of the cells in the battey, a short in the wiring or circuit board or bad contacts. Usually the only fix is to replace the battery.
1helpful
4answers
My dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
2answers
When putting the battery in the charger the red and green lights flash indicating a bad battery, cannot charge battery.
17helpful
3answers
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
4helpful
3answers
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
