Tumble dryer drum wont turn and ''empty water light'' permanently on.
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
