Electronics - Others Logo
Posted on Dec 16, 2009
Showing an error ''insert a disk in removable media''
I am using imation pendrive of 4 gb. it is not working write now. when even i inserted pendrive to pc, it is showing an error ''insert a disk in removable media''.
  • svsubbarao19 Dec 16, 2009
    yes i got (removable dirve f:). after that when i am trying to open it, it is showing message like "insert a disk into removable media";
  • Anonymous May 11, 2010
    Do you got icon ....... ie(Removable Drive F:)
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
723
Points
Its happened for my Transcend 4 Gb pendrive. I format dat using ONLINE RECOVERY TOOL from Transcend. Now its workin :-) :-) :-)
Please insert a disk into drive E: my pen drive
hey plz help me out of my pendrive...
1)whenever i insert pendrive the error cums please insert disk it gets detect but it shows this error and i cant open
2)second problem m facing dat my pendrive is not showing me in disk management just ican change a drive letter
3)i did everything by changing drive letter also...
plzz sumone can help me out...
Can tot open pen drive
you format your pendrive
or
go for nearest transcend service centre
or
your your pendrive is out of order
1helpful
Please Insert a Disk in Drive H:
you can replace your usb port, or YOU CAN USE YOUR PENDRIVE IN ANOTHER COMPUTER, by which you will come to know that whether your USB port is OK or not.
51helpful
6answers
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
KINGSTONE 2GB pENDRIVE dID NOT WORKING
show my drive but not open it and display insert disk to drive.
5helpful
3answers
My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
6helpful
3answers
Imation pendrive not working
sir my pendrive is not working well . it is not working on any computer. sir plz tell me what do i do. it is showing in my computer but not responding.
can u help m,e
sarwar from greater noida
1helpful
2answers
LOCKV116
hello, i have a Kingston 2GB Pendrive.I had run a program "LOCKv116.exe" on my pendrive and set password on it, but now after inserting pendrive to my pc, it is detected but when open it this message appears "please insert a disk into drive G:" If try to format it message is "There is no disk in drive G:"..If I run the program LOCKv16.exe it shows a message "please insert the device or run this utility as previledged user."
Top Electronics - Others Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you an Electronics - Other Expert? Answer questions, earn points and help others
