Washing Machines Logo
Katy Swush Posted on Dec 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont drain water Gorenje WA61111
The machine wont drain water out of it. It eventually lets u open the door, but water is still inside, like at bottom, not all of it i guess and clothes still soaking wet?
Gerry Harvey
Level 3:
Genius:
  • Asko Master 1,482 Answers
  • Posted on Dec 16, 2009
Gerry Harvey
Asko Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
379096
Points
4533
Locate the filter and clean, this should cure
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1332
Points
W600 washer only seems to work on #3 . also cloths have been comeing out smelling very bad like swer water ?? i drained all water out and flushed new water in still smells bad ???
Door wont open; water not draining. What's going on?
THe water must be totally drained and it is not. So go back into the area that you used to open the door and look for the drain. If you use that manual drain have a wet vacuum cleaner ready there will be a flood. When you take that drain plug out there should be a filter attached and you will find that a sock or something is plugging it up and not letting it drain. There is a chance the pump motor is bad but usually it is plugged drain.
2answers
Door wont open and F34 error message on our axxis front loader
This error message indicates that you have a Electrical Problem in your washing machine .
Make an attempt
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select RINSE & SPIN, and then select EXTRA
  • RINSE (to turn off the rinse option) if there is
  • excessive water in the washer.
  • Re-select cycle and press START. If the problem
SAM ANDERSON
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
1helpful
Need a Gorenje WA61111 Manual
the manul is here in pdf form:-
http://www.gorenje.co.uk/support/manuals?t=instructions&cm=wa61111
Door wont open after cycle has finished, have put on a different cycle didnt work either, pluged out maching for 30 min didnt work either, can you help
Hi.
The door does not open because there is water detected inside the machine. Water must be removed through the drain filter connected to drain pump.
Disconnect power.
If front loader remove the trim panel at the base of the machine. Top loader have access at the bottom or at the back.
Locate the drain filter access at one side.
Remove drain filter cap.
Collect water using containers (have them ready, a lot of water will flow out).
Put back cap and trim and reapply power.
Emptying water from drain lines is usually enough to unlock the door. If that does not work, then the door is opened reaching back side of the door latch (from inside the washer's cabinet). Access is from top, after removing panel, or from bottom. Some front loader has an emergency unlock cord inside that can be reached undoing completely the drain filter. The procedure requires disassembling and should be done by a technician.
You can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Loud noise when the water is draining out and it locks the door and stops and wont let you open it
It is a drain problem.
Either there is debris inside drain pump hose, or the pump itself is faulty.
The problem is fixed accessing the drain pump hose to check for a blockage.
the pump is accessed removing a panel, usually at the front side of the machine.
Steps are explained on user manual.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
It wont unlock after giving me the f04 code... cause it has water in it but i need to open it! it also the drum wont spin
sounds like your water pump has failed or blocked position your drain hose on the floor into a bucket or floor waste let water drain out you should be able to open door reposition drain hose in original position and try again if drain pump does not work check for blockage or replace faulty pump good luck
2answers
Cant drain and cant open the door
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Top Asko Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
