Where do i buy 3 extra links for my guess watch g75511m . the metal band on the watch is too small for my wrist.. is there a place that i can just order them online and put them in myself. thank you
Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
Place the watch face-down on a flat surface.
Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
Finish removing the pins with your pliers.
Keep the extra links in case you ever need extra room on your watch band.
mcdevito75 here, You"d need a special tool called a link pin remover, BEST BET, look for a small watch repair shop in your area, hold onto the extra links once removed as you may need them again.
mcdevito75 here, Anne Klien, nice watches, Retirn to the place where you purchased the watch and ask for 2--3 extra links for the band, most Brand watches will give 1--2--3-- extra links for free when asked for, but of course there"s no guarantee of them being free. Or you can look for a small watch repair shop in your area to match up the exsisting links or a new band.
mcdevito75 here, Many watches built today are not comming out with replacement Bands (straps, Bracelets) from the factory, the cost of makeing and keeping extra bands on hand is too high, they should at least have a few extra links to replace worn ones. Chances are your warantee is over on the watch and in that case, you"ll have to find another band, Bracelet on your own. Best Bet, visit a small watch repair shop in your area for another bracelet, band, Strap.
you would have to either have custom links made or buy a whole new band to be made the links pop out by pins and then shortened placed this way back together
but if you dont have extra links buying longer band is your better sollution cause creating a link or 2 to fits can be costly
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
