Re: Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
F03 error code means that the wash thermistor is "Open Circuit" genetally, this is located on the heater assy at the back of the machine.
Check the wiring and contacts between the thermistor and the PCB. If you
still get the fault it could be the Thermistor ( which means replacing
the heater ) or a faulty board. If it is under 5 years old - Call Hotpoint as you have a 5 years Parts Guaranteed.
Hope this helps and just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items. REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
