Code for sky remote or sky box code for samsung remote please
0060 does not work with my model of Samsung
I found the code can vary according to the particular Sky Remote you have.
Look in the battery compartment for the version (it will say something like Rev 8R or Rev 9F)
For my model I found code 1647 worked with a Rev 9 remote but not with a Rev 8 remote
I found codes 1277, 1340 and 0646 worked with a Rev 8 remote but not with a Rev 9 remote
Other codes that worked with certain older models of remotes included 2079, 1177 and 0088
Samsung codes for sky reomte
0060
065, 584, 037, 245, 476, 398, 516, 292, 318,
037
Click here for the link
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
need to find pairing codes for this tv
pairing codes
pairing codes
