Coby MP300  MP3 Player  Logo
Posted on Dec 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need driver information to install Coby MP300-1G
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 11, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470234
Points
19564
jouissaint islande
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 25, 2015
jouissaint islande
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
737
Points
Write your answer...comment trouver bluetooth
2helpful
How to install os on coby nbpc724
If you are unbricking your COBY, you need a firmware and a flasher for that device. You also need to know how to put your device to the proper USB mode (not mass storage) Flash Mode/upgrade firmware. You also need to install your ADB drivers.
Coby media manager for mp768 4G
First confirm that your computer is virus free. Second, check that media manager is compatible with your operating system. Third check your device (MP3Player) driver is properly installed on your system. For more info, I am sharing the link of coby media manager. You will find several complaint.
Coby Media Manager: Questions and Answers - Software Informer
1helpful
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
12helpful
3answers
My coby mp610 video player needs a mtv format converter. I cant find one online. I need it free as well. Any links?
Support for Coby media players is on cobyusa.com .
For the mtv converter, Coby Media Manager must be installed .
  1. Enter cobyusa.com as the address in Internet Explorer
  2. Next select the Support link
  3. Choose the fix for MP822 and follow the steps for the download of your operating system.
  4. After the download, install the file for Coby Media Manager
  5. Run Coby Media Manager: on page top in Tools > Device manager... select the MP610 in this converter.
  6. Add the MP610 and click OK to setup this device
  7. For the setup of the audio format added to the mtv video format, select DEVICE on the left side and next on the right side under MP610 select Device Configuration
  8. For the MP610, under the tab [Output file format] the audio bitrate can be changed, the audio format is fixed MP3; the video format is fixed MTV; the image format is fixed JPG .
On page top under Help find more information about using the software.
I'd appreciate your vote when this information was helpful.
When needing more help, just post a comment.
1helpful
This came with no software and i cannot seem to put any music or video on this mp3 player why
When not having the installation CD at your disposal, for support select
MP3 & Portable > MP3 & MP4 Players > MPC7085 in this page:
http://www.cobyusa.com/?p=doc
Start with the MP-C7085 setup guide:
http://www.cobyusa.com/files/setupguide/MPC7085_SG.pdf
More information about the device in MP-C7085 manual:
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
Software Coby Media Manager for the computer:
When running Operating System Windows 2000/XP/Vista:
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0924.exe
When running MAC OS X10.4 or later:
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0814.dmg
For a download right click the matching software and select "Save Target As..." to a location on the computer. Run the software by double clicking it.
When running Coby Media Manager select Tools > Device Manager...
to select the MP-C7085 from the list, Add and OK for this player setup.
Need more help ? Just post a comment.
No code for my universal remote.
I work for COBY tech support. Our customer service phone number is 1-800-727-3592.
I know this isn't what you want to hear, but unfortunately, there is no way to control a COBY dvd player with a universal remote. If you need a new remote, please call the number above so that we may give you the instructions for obtaining a replacement directly from COBY. The cost is $6.00.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
I have a new coby DP562 Digital Photo Frame and I need the Driver for it.Do you know where I can get it. It is not on the Coby website. My computer does not seem to have the correct driver for the USB...
What operating system are you running? According to the information I found, your photo frame comes with a driver disk for windows 98se. If you have windows ME or later, your computer should recognize the photo phrame without installing the disk.
2answers
Help bought @ a thift store
Probably not! Xp will see it! 98 needs drivers. Get em at Coby Electronics. Search for your mp3, it is there...Mp-cXXX Manual and drivers are there too!
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
