I have a dell D600 laptop that is charging the battery buth the battry and the charger are ok. can you help out or provide me with a well label circuit diagram?
Jimyhans
Thanks
If the laptop is not charging the battery, I would suggest to download and install the BIOS update at www.support.dell.com (if you have at least 20% battery charge) If this fix wont resolve the issue, i apologize but the motherboard needs to be replaced. Hope this helps
Sometimes, by downloading and installing the BIOS update may bot solve the problem if you are having the 3rd party after-market battery, because the battery does not have the right source code to communicate with the BIOS at all. If updating the BIOS can not fix the problem, you will need to get a good battery. I used to order from this place: www.dekcell.com
