RCA L42WD22 42 in. LCD Television Logo
Posted on Dec 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I try to hookup a Sony BDP-S360 blue ray player via HDMI and all i get is picture static
Paul
Level 2:
Sergeant:
  • Expert 381 Answers
  • Posted on Dec 15, 2009
Paul
Expert
Level 2:
Sergeant:
Answers
381
Questions
0
Helped
146025
Points
960
Try another Hdmi wire. Try another Hdmi source. Try another Hdmi port. If all else fails, replace the board with the Hdmi port on the tv.(I forgot the name of the board)
Sony bdps360 grainy picture issues
Unfortuneately the problem is in the RF circuits after the laser,but combined in the whole assembly. There is nothing you can do, except if warranty applies take it back.
I have gained a sony BDP-S360 Blue ray disc player, but without manual. What are the main parts necessary to adapt this equipmament on my TV? Which cable connections?
start from depending on your tv with hdmi-RGB-s-vid-component that is a little list starting from best to worst just match it up with your tv until you get a color fit and this will rule out best picture too then set tv input accordingly :)
Hi I would like help please in setting up my television to work with a new Blu-ray player. Television is a LG 32LC2D Blu-ray is a Sony BDP-S360 The Blu-ray and the cable works with a newer...
Hi and welcome to FixYa,
Initially, is there a cable box (receiver) used? If yes, please postback the brand & model number.
Offhand, best connection would be HDMI OUT of the Sony BDP-S360 to HDMI 2 of the LG 32LC2D.
Good luck and thank you for asking FixYa.
How do i make my sony bdp s360 play usa blue ray disks ''region code mismatch'' thanks Harry
Since this was also available in Europe and USA update with USA firmware should do it:
Firmware Sony BDP-S360
Head's up, you might lose regional play for Europe
5helpful
2answers
How to unlock sony bdp-s360 and make it multi region?
You will require either hacked firmware on a CD-RW or a key sequence input via your remote control or via a PDA with infrared capabilties
http://www.videohelp.com/dvdhacks/sony-bdp-s360/10264
Getting a serial no.
YOU CAN TRY LOOKING IN THE DVD PLAYERS MAIN MENU, SOME COMPANIES PLACE IT THERE.
On our Sony BDP-S360 DVD player, when we watch movies it keeps flashing a white bar across the bottom of the screen or flicker of white every once in a while.
you might have a loss connection?
what kind of cable are you using ?
hdmi / component / composite?
unplug the power cord to the ac outlet for 30 secs. and plug it in back. this is to refresh the unit.
turn on fan on the configuration of the unit ...
please read the operating manual ...
I am trying to hook up a Sony BDP-S360 via HDMI
I don't know what kind of TV you have, but on some TVs the HDMI inputs have to be enabled via the TV setup menu. Try looking at the setup status.
I need to unlock blue-ray sony bdp-s360
tv repeating hdmi signal out of range did a bad choice 1080p instead of 1080i how fix the problem? thank you
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
