Question about Behringer Music
Need Behringer Eurorack mixer power supply connector
Does anyone know of a (cheap) source for a replacement 3-pin AC output connector for a Behringer Eurorack mixer power supply cord? Or a generic model # for it? (I think that type used to be called an Amphenol connector, but I couldn't find that model in the only catalog I have.) It's a 1/2" inner diameter body, w/ locking ring. Here's a link to a pic at an Ebay store that sells them: http://cgi.ebay.com/Power-adapter-for-Behringer-Eurorack-Mixers-and-more_W0QQitemZ350290241553QQcmdZViewItemQQptZGuitar_Accessories?hash=item518eece811
But if that gets cut off, it's the 4th unit down here:
http://stores.ebay.com/Larsonics-Electric
Thanks for any help you can provide.
  • 2 more comments
  • scambuster1 Dec 17, 2009
    Thanks, but the one on Ebay is a different type. Yes, I remember some old mics used them. I also remember using a 2-cond type like the Behringer one as a 110 AC input to a surplus military piece of equipment, so maybe someone else is still making them?
  • Anonymous Mar 17, 2014
    I need a manual for a behringer EURORACK MXB1002 mixing desk
  • Anonymous Mar 27, 2014
    e2 was shown on the fx display screen.
  • Behringer Master
  • 5,603 Answers
Those were used for mic connectors at one time,,, they are related to the Amp 91-MC3F family of connectors and those are out of production and they are demanding $20 to $50 for one connector.
That is a ridiculous price and I would be tempted to swap out the connector for a more available design.
On eBay item 250401122616 is one but they want $13 pus $11 shipping which is a rip off.
These were used on some OLD CD radio mics.
Posted on Dec 15, 2009
    Sergeant:
  • 360 Answers
Hello, I have recently found a great place to get hold of "Behringer" parts in the UK. They are called EMS. They are friendly, down to earth people. I would recomend calling them on 01702 613 172. It's dfficult to obtain genuine Behringer replacements now days in the UK, but these guys are the nuts!
Posted on Jan 06, 2011
SOURCE:
Behringer PMP5000 Mixer. Connected a speakerOn cable to Output A while device was ON. Went to do the same thing on Output B and heard a spark. Turned off the mixer. Now, it will not come on. Checked the...
Chances are you've blown the output transistors. Speakon connectors cannot short out but jack connectors can and if it was not inserted properly you'll have presented a dead short to your powered mixer. In any event it is really bad idea to connect anything when it's switched on. If you're really lucky replacing the output stage (which will probably be dead short on the transistors) and re-adjusting the bias should sort you out.
Apr 08, 2017 | Behringer Europower Pmp5000 Powered Mixer...
My EURORACK UB2442FX-PRO has audio coming in but nothing coming out...
The outputs of these mixer needs to be connected to an active speaker.
An active speaker have an amplifier and a preamplifier.
Oct 02, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Connected wrong voltage power supply to my mixer when in Hong Kong.
If you have the polarity correct for the connector, and adequate output from the transformer with adequate regulation and filterning, there should be little problem with constructing one or hacking the cord off the dead supply and wiring it to a new one.
The question you need to ask yourself is whether that wait is worth it? If you need it to make money with it right now- then just use care in wiring the new supply up. I have lost track to how many times I have rewired a supply to make it work on something it was not originally on. As long as the specs on the new supply match those of the old one- no problem..
Sep 24, 2012 | Behringer Xenyx 1202fx Mixer 12 Input 2...
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Behringer ub802 mixer is buzzing even when no input when i hook my head phones into the headphone jack and main output jack
If it buzzes when you have no inputs AND no output leads connected, there is a problem with the power supply... HOWEVER if you have used UNBALANCED output cables instead of the REQUIRED TRS BALANCED output cables, it is possible the noise is being driven backwards and that is what you are hearing. Note that at full gains, there often is a tiny bit of noise, usually hiss. Also make sure the supply is powered from the SAME receptacle as the equipment this drives such as an amp or powered speakers.
Jul 18, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I am looking for a power connector wiring diagram for the Behringer Eurodesk MX3282A? It was rewired by someone and I think the wire combination is mixed up because when plugged in it seems to blow...
Some of the mixers have common connectors.
It appears that for the three pin connector, pin 2 is center tap of AC source, and pins 1 and 3 are the ends of the transformer windings.
This is from a schematic of a MX2643A which MAY be similar to yours. One of mine has a 3 pin Amphenol connector with a locking screw ring...
Use this info at your own risk, however, the power inout is easy to trace out to verify. They use a typical bridge rectifier to get plus and minus from the external transformer.
The pin markings on the connector CAN be confusing.
Suggest you use the light bulb trick of putting a small lamp in series with the 120 line as an auto reseting fuse.
Mar 03, 2010 | Behringer Music
I need halp how to plug up my behringer eurorack mx 3242x to my pc
Have a look at the Behringer UCA202. Its a Usb port that should help you do what you want.
May 15, 2009 | Behringer Music
AC POWER PACK BLOWN
David,   I dont like to be the bearer of bad news, but Behringer dissolved its service/repair center years ago.  In my opinion, this indicates little faith in the profitability of servicing Behringer products.  If the manufacturer wont even repair their own products, I wouldn't buy or use that brand if I had a choice.  Their products are good, WHEN THEY WORK.  They keep their prices low by using inexpensive, disposable quality components.  Most of their products aren't worth repairing.      Here are a few options to find your power supply.  Try Rogue music in New York, NY.  Here is the web address.
www.roguemusic.com
Here is another resource.  DBM pro Audio is an authorized Behringer Repair Center.  They are also in New York.  They will be able to tell you if your part is available from Behringer.  I'm very sorry to inform you of the inferiority of Behringer products.  I think the truth, though it hurts sometimes, is the best teacher.  P.S. if you ever visit DBM... next to the elevator, outside DBM's office is a one yard dumpster, it is always brimming with the carcasses of unrepairable Behringer mixing consoles.      Remember, when buying electronics, you get what you pay for...cheap price = cheap components (and usually headaches down the line) Good luck!  I wish you success on finding your power supply.  Michael Mittelsdorf
www.dbmproaudio.com
See my profile for my qualifications. DBM does all my electronics repair.
Jan 09, 2009 | Behringer Rx 1202fx 12 Channel Line and...
Music Logo
2,155 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
