Samsung YP-K3 MP3 Player Logo
Posted on Jan 21, 2008
Samsung YP-Z5 can't scroll
I can't move up and down on the menu screen. It is not locked.
jbrown2618
Anonymous
Level 1:
  • Contributor 70 Answers
  • Posted on Feb 05, 2008
Anonymous
Contributor
Level 1:
Answers
70
Questions
0
Helped
62243
Points
66
This is a common problem with these players. It is a hardware fault with the touch panel. It is probably why they were replaced with new models very quickly afterwards. The touch panel is a complete unit added to the device.
If you can get hold of a faulty unit on e-bay (with a working touchpad) you can easily replace the the touchpad without damaging any part of the mp3 player as it easily unscrews.
1helpful
I need a replacement usb cable to connect my samsung YP-Z5 MP3 player to my computer
You can purchase a replacement USB cable for Samsung YP-Z5 MP3 Player from amazon >>LINK
I have a samsung yp-z5f but i can't get in menu and it keeps freezeing.i reseted it but sill nothing.can you help?
A firmware upgrade may solve the issue. To upgrade firmware follow these steps:
  1. Download the firmware file from the Samsung Download Center by clicking here.
  2. Remember to save the file to your desktop or documents.
  3. Uncompress the downloaded file in a folder (use winrar or winzip). DATA file will be displayed.
  4. Connect the player to your PC with the USB cable.
  5. Right click on the Start button, and then left click Explore to open Windows Explorer on your PC. [Samsung YP-Z5] is displayed in Windows Explorer.
  6. Select the uncompressed files and drag-and-drop it into the Samsung YP-Z5 Data folder.
  7. Disconnect the YP-Z5 from your PC. After disconnecting the USB Cable, the upgrade screen appears.
  8. Select [Upgrade] to upgrade firmware.
Try it and see.
MP3 driving me mad
i cannot turn on my samsung 1G mp3 yp-1 after last recharge.
How can i turn it on or reset it?
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Samsung YP-Z5
From my experience this is a hardware fault with the touchpad. Luckily you can buy a faulty player on ebay and replace the touchpad - make sure the fault on the faulty one is not the same!
The player is is easy to take apart and the touchpad easy to replace.
2answers
Samsung yp-z5 scroll panel stopped working.
This is a common hardware fault with this player. I guess it is why the model has been replaced.
The cheapest solution is to buy a faulty player from ebay - around £10 including postage and replace your faulty one. Make sure to check the faulty one does not have the touchpad fault.
It is straightforward to replace the touchpad.
Touch pad will not work
did u get some water on it too like me?
7helpful
6answers
Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
Down scroll
Try reseting the player. It might not work all the time, but this was the first time my down scroll ever locked up on me, and the reset button fixed the problem. It might just be a temporary solution, but at least it's something.
Keeps restting itself
Firstly, try "re-setting" the Z5 (ie micro switch) first. If this doesn't resolve, then firstly save a backup of all your files...then use the 'format' function (ie open My Computer, then open the YP-Z5 folder, then look for the Format function), which will clean out your entire memory, including hidden files. Then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your Z5. Always update your Z5 with latest firmware (appropriate with your Windows OS). Good luck.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
