Question about Amana Refrigerators
Leaky water dispenser. How to fix - Amana Refrigerators
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on Dec 15, 2009
SOURCE:
What is causing the water dispenser to drip? Ice is making fine
most likely a leaky water inlet valve or clogged dispenser defrost pipe or water tank leaking or water filter leaking.
Aug 06, 2014 | Samsung RS2630SH Side by Side Refrigerator
How can I fix my fridgidaire refrigerator model #frs26h58sb4 leaky water dispenser.
Good Morning Friend,
I understand you are trying to repair the leaky water dispenser on your Frigidaire refrigerator, model# FRS26H58SB4. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals for this repair. I suggest contacting your local authorized technician for further assistance. I hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Refrigerators
Good Morning Scott,
-Best Regards-
WP
How to fix a leaking water dispenser?
remove the service panel, look for a loose or leaky hose. hose is inexpensive and easy to replace. if its coming from the cylinder and is cracked or split, it will need to be replaced. many companys will give you a 1 year contract of buying there water they deliver and you get a free water cooler.
Apr 23, 2014 | Kenmore Side by Side Refrigerator
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
Water dispenser leaks on fsc23bbdsb3 frigidaire
The valve that shuts the water off is leaky. Replace it or the washer . The lever also may not be set right to stop water flow.
Feb 03, 2013 | Refrigerators
The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
Leaky dispenser-------
Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
Water is constantly driping from the dispenser area
Water dripping from a water dispenser is caused by a leaky water inlet valve which is on the back where the water supply is connected. It needs to be replaced.
Aug 24, 2011 | Whirlpool Refrigerators
Water continuouly run out and overfills the cup
Water continuously running from a water dispenser is caused by a leaky water inlet valve which is on the back where the water supply is connected. It needs to be replaced.
Unless the dispenser switch is stuck. When you depress the switch you should hear the water inlet valve open and it should stop when you release it.
Nov 05, 2010 | Refrigerators
I have a leaky spigot what can I do
If the spigot means the end of the water tube in the water dispenser, and it steadily drips even if the dispenser is not used for 10 minutes or so - replace the water valve. If the dispenser drips water mostly wright after you used it - you might have some air bubbles in the refrigerator water tubing.
Oct 17, 2009 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
117 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
