Toshiba 62HMX84 62" Rear Projection HDTV Logo
Posted on Dec 15, 2009
Just replaced the lamp on my Toshiba 62HMX84. Picture still is not coming on I have sound. When you turn on the TV you hear a clicking sound that goes away and then the TV try's to restart itself Thinking it might be the ballast any thoughts?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 22, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
820
Points
I have a 62HM84 Toshiba TV. I lost picture on my TV in the past i have bought the lamps and i just put it on and the picture comes on. This time when i replaced the lamp nothing happens no picture. It tries 8 times to turn on, but nothing happens. Can you help me with is what is the problem.
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Dec 15, 2009
Anonymous
Contributor
Level 1:
Answers
34
Questions
Helped
11224
Points
96
It sounds as if you have a weak ballast, I would replace it, I have seen this problem in 52hM84's as well, but those ballasts are no longer available. Sounds like you have a bad ballast
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
1helpful
I have a Toshiba #50HP16. The picture just went out without any warning, could still hear the sound. Turned it off and now it will not come back on, not even the sound. You can hear licking like it is...
U hear alots of clickings,when power turn on?Yes,the tv projection lamp might be dead also,require replacing?But the board call the Ballast board is 100% dead.This Ballast board job,it to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy parts like projection lamps and Ballast boards for DLP projection tvs brands.
I replaced the lamp- now the picture won't come up
U hear alot of clicking,when power on to the tv?Yes,the ballast board,that the board that help to ignite the projection lamp is dead.The Ballast board is dead.Change the Ballast board.
1helpful
Another Bad Ballast?
Go to this website and type in your model number see what they list in parts /prices They might have free service Manual you can print out online.
1-800-638-3328 wait untill you get ballast board ,before making any desision about more parts
If it turns out that ballast didnt clear problem then return it to company.Have you Checked Lamp Fan, Ballast Fan,some DLPs will have up to 4 Fans, if fans stops cooling set will shut off
1helpful
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
2answers
No picture, starts normally then shuts off. blue light stays on. replaced lamp, and still the same problem. toshiba 62hm196
If a tv turns off after being turned on It is enambling the safe mode to prevent greater damage. It has probably got a bas chip or sync switch on the power board.
1helpful
2answers
TOSHIBA 62HM15A
It sounds like you need to replace the lamp. Take the lamp assembly out and inspect it. It will have a white smokey look or may be cracked if it is bad.
2answers
62HM15
Same problem with mine...
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
