I have a mx 900 the lights work it beeps but wont turn the tv on or off or change the channels when i press watch enter it says reset but nothing happens
Try resetting the display back to standard definition -
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep
Reset the remote control and use with the equipment .
If it does adjust volume, change channel. then use have to get another one of different model
SETTING V-CHIP This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls and restrictions. This function is to prevent your children from watching violence or sexual scenes that you may choose to exclude. Press the MENU button and press the SET + or – button to select the V-CHIP SET option, then press the ENTER button. Enter your password (4 digits) using the Direct channel selection buttons (0-9). In the event of entering incorrect password press the RESET button. Then press the ENTER button. Enter the same password for confirmation, then press the ENTER button. Press the SET + or – button to select the V-CHIP option. Press the ENTER button to select the ON. Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press the ENTER button. Press the SET + or – button to select the desired rating for the applicable video or TV channel. Press the ENTER button.
And to change or put in a new password: NOTES: • If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD" option then enter your new password. • The V-Chip function is activated only on programs and tapes that have the rating signal. • Once you block a program using the V-Chip function, the blocked program cannot be watched based on the content of the show. When the program starts, the "INPUT PASSWORD" will appear on the screen. When you want to release the V-Chip temporarily, enter the password. If you change the channel or turn off the TV while the V-Chip function was temporarily released, the original setting will be resumed. If you return to the channel you were watching you must re-enter your password to temporarily release your V-Chip function again. • When you watch the TV from the cable box or the VCR with the RF Modulator, then you release the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The TV channel is not used in this case. • When changing the channel with the cable box or the VCR, approximately 10 seconds will pass until the program appears.
These are the steps to reset the DTV features and unfreeze your TV:
Ensure the tv is in analogue mode, not dtv and turn it off.
With the remote:
press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
Turn the tv back on & it'll re tune all its channels. DTV should be working again.
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for
about 20mins. Plug it all back in. Turn on the CPU! Also make sure if
your device requires "DRIVERS" or if you have a CD download and install
that before anything.
